here you can find these excellent books.
Pressure Relief Devices ASME & API Code simplified
Pressure Relief Devices by McGraw Hill addresses the various codes and recommended standards of practice for the maintenance and continued operations of pressure relief valves as specified by the American Society of Mechanical Engineers and the American Petroleum Institute.
Features:
• ASME and API code requirements
• Design specifications and code calculations
• Manufacturing and pressure relief valves
• Sizing and selection of pressure relief valves and rupture disks
• Installation, operation, maintenance, inspection, and testing
Contents
• Fundamentals
• Materials
• Design
• Manufacturing
• Safety Valves for Boilers
• Safety Relief Valves for Pressure Vessels
• Safety Relief Devices for Petroleum Industries
• Installation
• Operation
• Inspection
• Repairs
• Maintenance
Pressure Vessels Asme Code Simplified
Pressure vessels are found everywhere -- from basement boilers to gasoline tankers -- and their usefulness is surpassed only by the hazardous consequences if they are not properly constructed and maintained. This essential reference guides mechanical engineers and technicians through the maze of the continually updated International Boiler and Pressure Vessel Codes that govern safety, design, fabrication, and inspection. * 30% new information including coverage of the recent ASME B31.3 code
Revised and updated, this classic engineering tool simplifies the tasks of understanding and applying the complex ASME Code for fabricating, purchasing, testing, and inspecting pressure vessels.
Features:
• An understanding of the history of standards for Code compliance
• The various ways different standards acheive compliance
• The difference and interaction between various standards
Clearly explaining changes in B31.3, this Eighth Edition of Pressure Vessels: The ASME Code Simplified makes it easier to achieve Code compliance on any pressure-vessel-related project, to obtain ASME Code certification, and to meet performance goals in the most cost-effective way possible.
This reference explains the value of Code standards, shows you how the Code applies to each component, and clarifies requirements that may be confusing. This valuable text also features tables for caluclating allowable internal pressures.
Learn how to comply with ASME standards for:
• Safety procedures for design and maintenance
• Inspection and quality control
• Welding
• Nondestructive testing
• Fabrication and installation
• Pressure vessels in nuclear power plants
Filled with helpful solutions to typical problems, the new edition of this handy working tool will give you the expertise you need to deal with all the changes in requirements for pressure vessels.
Contents
1. Origin, Development and Jurisdiction of the ASME Code
2. Descriptive Guide to the ASME Code Section VIII, Division 1 Pressure Vessels
3. Elements of Joints Design for Heads
4. Design for Safety
5. Guide to Quality Control Systems for ASME Code Vessels
6. Inspection and Quality Control of ASME Code Vessels
7. Welding, Welding Procedure, and Operator Qualification
8. Nondestructive Examination
9. ASME Code Section VIII, Division 2 Alternative Rules
10. Nuclear Vessels and Required Quality Assurance Systems
11. Department of Transportation Requirements for Cargo Tanks
12. ISO 9000 Quality Assurance Systems
