Results 1 to 5 of 5
Thread: AASHTO Standards...
  1. AASHTO Standards...
    Hi guys,
    I'm working now in test for soils and concrete and need the updated of AASHTO Standards for continue this work...
    I hope your support...
    Re: AASHTO Standards...
    i need it too plz
  5. Re: AASHTO Standards...
    Same here. Thus astm and aashto have the same standard?
  6. Re: AASHTO Standards...
    1 M154 2000 Standard Specification for Air-Entraining Admixtures for Concrete
    2 M194 2000 Standard Specification for Chemical Admixtures for Concrete
    3 M6 2002 Standard Specification for Fine Aggregate for Hydraulic Cement Concrete
    4 M80 1999 Standard Specification for Coarse Aggregate for Hydraulic Cement Concrete
    5 PP23 1995 Standard Practice for Evaluating the Condition of Portland Cement Concrete Bridge Components - 2000 Edition
    6 T11 2005 Standard Method of Test for Materials Finer Than 75-μm (No. 200) Sieve in Mineral Aggregates by Washing
    7 T134 2000 Standard Method of Test for Moisture-Density Relations of Soil-Cement Mixtures
    8 T140 2005 Standard Method of Test for Compressive Strength of Concrete Using Portions of Beams Broken in Flexure
    9 T180 2010 Standard Method of Test for Moisture-Density Relations of Soils Using a 4.54-kg (10-lb) Rammer and a 457-mm (18-in.) Drop
    10 T193 2010 Standard Method of Test for The California Bearing Ratio
    11 T224 2001 Standard Method of Test for Correction for Coarse Particles in the Soil Compaction Test
    12 T23 2002 Standard Method of Test for Making and Curing Concrete Test Specimens in the Field
    13 T260 1997 Standard Method of Test for Sampling and Testing for Chloride Ion in Concrete and Concrete Raw Materials
    14 T27 2006 Standard Method of Test for Sieve Analysis of Fine and Coarse Aggregates
    15 T89 2010 Standard Method of Test for Determining the Liquid Limit of Soils
    16 T90 2004 Standard Method of Test for Determining the Plastic Limit and Plasticity Index of Soils
    17 T96 2002 Standard Method of Test for Resistance to Degradation of Small-Size Coarse Aggregate by Abrasion and Impact in the Los Angeles Machine
    18 T99 2001 Standard Method of Test for Moisture-Density Relations of Soils Using a 2.5-kg (5.5-lb) Rammer and a 305-mm (12-in.) Drop
  7. Re: AASHTO Standards...
    Please reload the files as they are no longer available. Thank you.
  1. API standards
    By ayoubhk in forum Safety And Environment
    Last Post: 12-15-2014, 02:29 AM
  2. API Standards and RP
    By attar in forum Materials Science &Corrosion
    Last Post: 07-09-2013, 08:39 AM
  3. BS/DIN/EN - STANDARDS FOR P&ID's
    By ceeee83 in forum Engineering Certificates
    Last Post: 04-27-2013, 08:10 AM
  4. Need the following IEC standards
    By SA_FETY in forum Safety And Environment
    Last Post: 12-09-2011, 05:11 AM
  5. IEC Standards
    By sunset_eagle in forum Electrical & Power Engineering
    Last Post: 10-25-2010, 08:52 PM
