Page 1 of 2 1 2 LastLast
Results 1 to 12 of 19
Thread: Glossary of Petroleum Industry Common Terms
    Thumbs up Glossary of Petroleum Industry Common Terms
    [CENTER]Glossary of Petroleum Industry Common Terms/CENTER]
    A
    AAMA
    American Automobile Manufacturers
    Association
    Absorption
    The process by which one substance draws into
    itself another substance. Examples: a sponge
    picking up water; an oil recovering gasoline from
    wet natural gas.
    ACEA
    Association des Constrecteurs Europeens
    (Association of European Automotive
    Manufacturers)
    Acid
    A member of an important and fundamental
    category of chemical substances characterized
    by having an available reactive hydrogen and
    requiring an alkali to neutralize them. Acid
    solutions usually have a sour, biting and tart
    taste like vinegar.
    Acid Sludge
    The residue left after treating petroleum oil with
    sulfuric acid for the removal of impurities. It is
    a black, viscous substance containing spent
    acid and impurities.
    Acid Treating
    A refining process in which unfinished petroleum
    products, such as gasoline, kerosene and
    lubricating oil stocks, are contacted with sulfuric
    acid to improve their color, odor and other
    properties.
    Acidity
    The amount of free acid in any substance.
    Additive
    An agent used for imparting new, or for
    improving existing characteristics of lubricating
    oils or greases.
    Additive Level
    The total percentage of all additives in an oil.
    Adhesion
    The force or forces causing two materials such
    as a lubricating grease and a metal, to stick
    together.
    AFV
    Alternate Fuel Vehicle
    AGMA
    American Gear Manufacturers Association
    Air Entrainment
    The incorporation of air in the form of bubbles
    as a dispersed phase in the bulk liquid. Air may
    be entrained in a liquid through mechanical
    means and/or by release of dissolved air due
    to a sudden change in environment. The
    presence of entrained air is usually readily
    apparent from the appearance of the liquid (i.e.,
    bubbly, opaque, etc.), while dissolved air can
    only be determined by analysis.
    Alkali
    In chemistry, any substance having basic
    properties. The term is applied to hydroxides of
    ammonium, lithium, potassium, and sodium.
    They are soluble in water and have the power
    to neutralize acids and form salts. They turn red
    litmus blue. In a more general sense, the term
    is also applied to the hydroxides of the so-called
    alkaline earth metals- barium, calcium and
    strontium.
    Almen EP Lubricant Tester
    A journal bearing machine used for determining
    the load-carrying capacity or extreme pressure
    properties of gear lubricants.
    Ambient Temperature
    Temperature of the area or atmosphere around
    a process, (not the operating temperature of the
    process itself ) .
    Anhydrous
    Free of water, especially of crystallization.
    Aniline Point
    The minimum temperature for complete
    miscibility of equal volumes of aniline and the
    sample under test ASTM Method D 611. A
    product of high aniline point will be low in
    aromatics and naphthenes and, therefore, high
    in paraffins. Aniline point is often specified for
    spray oils, cleaning solvents, and thinners,
    where effectiveness depends upon aromatic
    content. In conjunction with API gravity, the
    aniline point may be used to calculate the net
    heat of combustion for aviation fuels.
    Anti-foam Agent
    An additive used to control foam.
    Antifreeze Solution
    A fluid, such as ethylene or propylene glycol,
    which is added to or used to replace the water
    in the cooling system of engines in order to
    prevent freezing.
    Anti-friction Bearing
    A type of bearing using rollers or balls. They
    are also known as rolling bearings.
    Antiknock
    Resistance to detonation or pinging in sparkignition
    engines.
    Antioxidant
    A chemical added to lubrication oils to resist
    oxidation.
    API
    American Petroleum Institute
    API Engine Service Classification System
    Classifications and designations for lubricating
    oils for automotive engines developed by API
    in conjunction with SAE and ASTM. API Service
    categories: Service SJ, SH, SG, SF, SE, SD,
    SC, SB, CH, CG-4, CF, CF-II, CE, CD, CD-II,
    CC, CB, and CA.
    B
    Barrel
    A unit of liquid measure comprised of 42 gallons.
    It is used to measure quantities of crude oil
    gasoline and fuel oils.
    Batch
    Any quantity of material handled or considered
    as a unit in processing.
    Bentonite
    The mineral montmorillonite, a magnesiumaluminum
    silicate. It is used as a treating agent
    also, as a component of drilling mud, and in
    greases.
    Benzene
    Colorless liquid hydrocarbon, C6H6, with one
    ring of carbon atoms. Made from coal tar and
    by catalytic reforming of naphthenes, it is used
    in the manufacture of phenol, styrene, nylon,
    detergents, aniline, phthalic, anhydride,
    biphenyl, nitrobenzene, chlorbenzene; as a
    solvent; and as a component of high-octane
    gasoline .
    Benzene Insoluble
    That portion of the normal pentane insoluble in
    used lubricating oils which is not soluble in
    benzene, and which may include the insoluble
    contaminants from external sources, some
    matter produced by oxidation and thermal
    decomposition of the oil, the oil additives or the
    fuel. (ASTM Method D 893) .
    Blending
    The process of mixing lubricants or components
    for the purpose of obtaining the desired physical
    and/or chemical properties (see compounding ) .
    Bloom
    Fluorescence is the color of an oil by reflected
    light which could differ from its color by
    transmitted light.
    Boiling Point
    The temperature at which a substance boils, or
    is converted into vapor by bubbles forming
    within the liquid; it varies with pressure.
    Bottoms
    The liquid which collects in the bottom of a
    vessel (tower bottoms, tank bottoms), either
    during a fractionating process or while in
    storage.
    Boundary Lubrication
    The state of lubrication when conditions exist
    that do not permit the formation of a lubricant
    film capable of completely separating the
    moving parts.
    Bright Stock
    Refined, high viscosity base oils usually made
    from residual stocks by suitable treatment, such
    as a combination of solvent extraction, propane
    asphating or catalytic dewaxing.
    British Thermal Unit (BTU)
    The quantity of heat required to raise, by 1°F,
    the temperature of one pound of water at its
    maximum density (39.2°F).
    BS&W
    The material which collects in the bottom of
    storage tanks, usually composed of oil, water
    and foreign matter. Also called bottoms, or
    bottom settling and water.
    BTC
    British Technical Council
    Bunker “C” Fuel Oil
    A heavy residual fuel oil used by ships and
    large-scale heating installations. The United
    States Navy calls it “Navy heavy”; in industry, it
    is often referred to as No. 6 fuel.
    C
    CAFE
    Corporate Average Fuel Economy
    Calorie
    1. The amount of heat required to raise the
    temperature of 1 g of water 1°C, at or near the
    temperature of maximum density. This unit is
    called a “small calorie”, or “gram calorie”.
    2. The amount of heat required to raise the
    temperature of 1 kg of water 1°C. This unit is
    called a “large calorie” or “kilogram-calorie”.
    Capillary Viscometer
    A viscometer in which the oil flows through a
    capillary tube.
    CARB
    California Air Resources Board
    CCMC
    Comite des Constructeurs d’Automobile du
    Marche Commun (Common Market Automobile
    Manufacturers Association)
    CEC
    Coordinating European Council
    Centistoke (cSt)
    The worldwide unit of kinematic viscosity. (See
    inside cover for Viscosity Grade Comparisons
    Chart)
    Cetane Number (calculated)
    The cetane number of distillate fuels as
    estimated from the API gravity and mid-boiling
    point by using a formula given in Appendix II of
    ASTM Method D 975. This estimate is used if
    a standard test engine is not available, or if the
    sample is too small for an engine test.
    Cetane Number (test method)
    The percentage by volume of normal cetane, in
    a blend with heptamethylnonae (HMN), which
    matches the ignition quality of the fuel when
    compared by the procedure specified in ASTM
    Method D 613.
    Cetane Number Improver
    A substance which, when added to a diesel fuel,
    has the effect of increasing its cetane number.
    In this class are nitro alkanes, nitrates, nitro
    carbonates and peroxides.
    Cetane Index
    An approximation of cetane number based on
    API gravity and mid-boiling point of fuel.
    CFR
    Coordinating Fuel and Equipment Research
    Committee, composed of engine-manufacturers,
    petroleum-refiners, petroleum-consumers,
    universities, government and other technical
    people who supervise cooperative testing and
    study engine fuels for the Coordinating Research
    Council, Inc.
    Channeling
    1. The phenomenon observed among gear
    lubricants and greases when they thicken, due
    to cold weather or other causes, to such an
    extent that a groove is formed through which
    the part to be lubricated moves without actually
    coming in full contact with the lubricant.
    2. A term used in percolation filtration; may be
    defined as a preponderance of flow through
    certain portions of the clay bed.
    Chromatography
    A method of separation based on selective
    absorption. A solution of the substance is
    allowed to flow slowly through a column of
    absorbent. Different substances will pass with
    different speeds down the column and will
    eventually be separated into zones. The column
    core can then be pushed out and the zones of
    material cut apart, or the zones can be eluted
    by passing more solvent down the column and
    collecting it in small fractions.
    Partition Chromatography involves the
    selective solution of the desired material
    between two solvents. The final solvent,
    usually water, is used to wet the solid material
    packed in the column, and the first solvent
    containing the desired material is poured into
    the column as described.
    Paper Chromatography is a micromethod.
    A drop of the liquid to be investigated is placed
    near one end of a strip of paper. This end is
    immersed in solvent which travels down the
    paper and distributes the materials present
    in the original drop selectively. Comparison
    with known substances makes identification
    possible.
    Gas Chromatography is an analytical
    technique for separating mixtures of volatile
    substances. The procedure consists of
    introducing the mixture to be examined into the
    chromatographic column and washing it down
    (eluting it) with an inert gas. The column is
    packed with adsorbent materials which
    selectively retard the components of the sample.
    D
    DAP
    Detroit Advisory Panel
    Degree Day
    A unit of temperature. Experience has shown
    that, for buildings requiring an inside
    temperature of approximately 70°F, the amount
    of fuel or heat used per day is proportional to
    the number of degrees the average outside
    temperature falls below 65°F. The degree-day
    is based upon this principle. The number of
    degree-day (65°F base) for a given period is
    the difference between 65°F and the United
    States Weather Bureau daily mean
    temperature, when the latter is less than 65°F,
    multiplied by the number of days.
    Degree Engler
    A measure of viscosity. The ration of the time
    of flow of 200 ml of the liquid tested, through
    the viscometer devised by Engler, to the time
    required for the flow of the same volume of water
    gives the number of degrees Engler.
    Density
    The mass of a unit of volume of a substance.
    DEO
    Diesel Engine Oil
    Detergent Oil
    A lubricating oil possessing special sludgedispersing
    properties usually conferred on the
    oil by the incorporation of special additives.
    Detergent oils hold sludge particles in
    suspension and thus promote cleanliness
    especially in internal-combustion engines.
    Dielectric Strength
    A measure of the insulating properties of
    electrical insulating oils for use in cables,
    transformers, circuit breakers and similar
    apparatus (ASTM Method D 877).
    Diesel Index
    An expression for the ignitability of a fuel relative
    to its aniline point:
    Diesel index = aniline pint (°F) X API gravity
    100
    Diester Oil
    A synthetic lubricating fluid made from esters;
    also called ester oil.
    DIN
    Deutsche Industrie Norm
    Dispersant
    A dispersing agent, which holds a very finely
    divided substance in a dispersed state in the
    carrier fluid.
    Distillate
    Wide range of products produced by distillation.
    DKA
    Deutscher Koordinierungsausschuss
    Dropping Point
    In general, the dropping point is the temperature
    at which the grease passes from a semisolid to
    a liquid state. This change in state is typical of
    greases containing conventional soap
    thickeners. Greases containing thickeners other
    than conventional soaps may, without change
    in state, separate oil.
    Dry-film Lubricant
    Solid material left between two moving surfaces
    to prevent metal-to-metal contact, thus reducing
    friction and wear. Such materials are especially
    useful in the region of boundary lubrication, and
    for lubrication under special conditions of
    extremely high or low temperature where usual
    lubricants are inadequate. They may be applied
    in the form of a paste or solid stick, or by
    spraying, dipping or brushing in an air-drying
    carrier which evaporates leaving a dry film.
    Some examples are graphite, molybdenum
    disulfide, boron nitride and certain plastics such
    as tetrafluorethylene resins.
    Dual-fuel Engine
    A diesel engine which may be operated as an
    oil diesel, a gas diesel, or a combination of both,
    as it is equipped with controls or parts to permit
    operating as one or the other
    E
    EC & EC II
    Energy Conserving and Energy Conserving II
    EFTC
    Engine Fuels Technical Committee
    Elastohydrodynamic Lubrication
    Lubrication modified to take into consideration
    the elastic properties of the bearing material and
    the viscosity increase of the lubricant under
    concentrated load.
    ELTC
    Engine Lubricants Technical Committee
    EMA
    Engine Manufacturers Association
    Emulsifier
    A substance used to promote or aid the
    emulsification of two liquids and to enhance the
    stability of the emulsion.
    EOLCS
    Engine Oil Licensing and Certification System
    EPA
    Environmental Protection Agency
    EP Agent
    An extreme pressure additive introduced into a
    lubricant to improve the load-carrying or antiweld
    qualities.
    EP Lubricant
    Any of the lubricating oils or greases which
    contain an extreme pressure additive
    specifically introduced to prevent metal-to-metal
    contact in the operation of highly loaded gears.
    In some cases, this is accomplished by the
    additive reacting with the metal to form a
    protective film.
    F
    Fat
    An animal or vegetable oil which will combine
    with an alkali to saponify and form a soap.
    FFV
    Flexible-Fuel Vehicle
    Fiber Grease
    A grease with a distinctly fibrous structure, which
    is noticeable when portions of the grease are
    pulled apart.
    Filler (lubricants)
    Any substance, such as talc, mica or various
    powders, which may be added to a grease to
    make it heavier in weight or consistency, but
    which serves no useful function in making the
    grease a better lubricant. (Editor’s note: Such
    filler may also be added to certain lubricating
    oils or other lubricants).
    Film Strength
    The property of an oil which enables it to
    maintain an unbroken film on lubricated
    surfaces under operating conditions, where
    otherwise there would be scuffing or scoring of
    the surfaces.
    Fire Point
    The lowest temperature at which, under
    specified conditions in standardized apparatus,
    a petroleum product vaporizes sufficiently
    rapidly to form above its surface an air-vapor
    mixture which burns continuously when ignited
    by a small flame.
    Fire Point Test (COC)
    (see Cleveland open-cup tester)
    Flash Point
    The lowest temperature at which vapors arising
    from the oil will ignite momentarily (i.e., flash)
    when exposed to a flame.
    Flash Point Test (COC)
    Flash Point Test
    (Pensky-Martens closed tester)
    A method of test for the determination of the
    flash point of liquid fuels flashing below 175°F,
    with the exception of fuel oils.
    Flash Point (Tag closed-cup tester)
    Floc Point
    The temperature at which wax or solids
    separate in an oil.
    Foam
    An agglomeration of gas bubbles separated
    from each other by a thin liquid film which is
    observed as a persistent phenomenon on the
    surface of a liquid.
    Four-Ball Tester
    This name is frequently used to describe either
    of two similar laboratory machines, the Four-
    Ball Wear Tester and the Four-Ball EP Tester.
    These machines are used to evaluate a
    lubricant’s anti-wear qualities, frictional
    characteristics or load carrying capabilities. It
    derives its name from the four ½ inch steel balls
    used as test specimens. Three of the balls are
    held together in a cup filled with lubricant while
    the fourth ball is rotated against them.
    Fretting Corrosion
    A special case of fretting in which one or more
    of the surfaces, or the wear particles therefrom,
    react with their environment. Mechanical wear
    initiates fretting, then chemical action or
    “corrosion” results from the exposure of virgin
    metal surface to the air.
    Front-end Volatility
    A term applied to the volatility of the lower boiling
    fractions of gasoline.
    Fuel Sensitivity
    The response of a motor fuel to the change in
    engine severity between the operating
    conditions of the ASTM Research Method (D
    908) and ASTM Motor Method (D 357);
    numerically equal to the difference between the
    Research and Motor octane numbers.
    FZG Test
    A German gear test for evaluating EP
    properties.
    G
    Gasohol
    Fuel mixture of gasoline and methyl alcohol
    (methanol).
    GATT
    General Agreement on Tariffs and Trade
    Gravity (See API gravity)
    Grease
    A lubricant composed of a lubricating fluid,
    thickened with soap or other material to a solid
    or semisolid consistency.
    H
    Heat Transfer Oil
    A medium used for the transfer of heat.
    Herschel Demulsibility Number
    A number which indicates the ability of an oil to
    separate from water under conditions specified
    by the Herschel Demulsibility Test.
    Humidity Cabinet Test
    A test used to evaluate the rust-preventing
    properties of metal preservatives under
    conditions of high humidity (ASTM Method D
    1748).
    Hydrocarbon
    A compound containing only hydrogen and
    carbon. The simplest hydrocarbons are gases
    at ordinary temperatures; but with increasing
    molecular weight, they change to the liquid form
    and, finally, to the solid state. They form the
    principal constituents of petroleum.
    Hydrodynamic (fluid film) Lubrication
    An oil film which provides a pressure equal to
    the load. This pressure enables the moving
    parts to float on a layer of lubricant.
    Hydrogenation
    The chemical addition of hydrogen to a material.
    In non-destructive hydrogenation, hydrogen is
    added to a molecule only if, and where,
    unsaturation with respect to hydrogen exists.
    In destructive hydrogenation, the operation is
    carried out under conditions which result in
    rupture of some of the hydrocarbon chains
    (-----ing); hydrogen is added where the chain
    breaks have occurred.
    Hypoid Gears
    Gears in which the pinion axis intersects the
    plane of the ring gear at a point below the ringgear
    axle and above the outer edge of the ring
    gear, or above the ring-gear axle and below the
    outer edge of the ring gear.
    K
    Kinematic Viscosity
    The ratio of the absolute viscosity to the density
    at the temperature of the viscosity
    measurement. The metric units of kinematic
    viscosity are the stoke and centistoke, which
    correspond to the poise and centipoise of
    absolute viscosity.
    I
    ILMA
    Independent Lubricant Manufacturers
    Association
    ILSAC
    International Lubricants Standardization &
    Approval Committee
    Inhibitor
    A substance in a petroleum product which
    prevents or retards undesirable chemical
    changes from taking place in the product, or in
    the condition of the equipment in which the
    product is used. Commonly used inhibitors are
    used to prevent or retard oxidation or corrosion.
    Initial Boiling Point
    According to ASTM Method D 86, the recorded
    temperature when the first drop of liquid falls
    from the end of the condenser.
    Ink Oil
    Any of the petroleum oils used as carriers for
    the pigment used in making printing inks.
    Insulating Oil
    An oil used in circuit breakers, switches,
    transformers and other electrical apparatus for
    insulating, and/or cooling. In general, such oils
    are well-refined petroleum distillates of low
    volatility, with resistance to oxidation and
    sludging.
    IP
    Institute of Petroleum
    ISO
    International Standards Organization
    This organization which is worldwide in scope
    sets standards and classifications for lubricants.
    An example is the ISO viscosity grade system
    M
    Mean Hertz Load
    (See load wear index (LWI)
    Metal Deactivator
    A fuel or lubricant additive, which converts into
    an inactive form, the traces of metal (such as
    copper in fuels) and metal surfaces (such as
    copper in fuel lines) which, in the absence of
    the deactivator would catalyze gum formation
    and other oxidation.
    Mid-Continental Crude
    Petroleum oil obtained from the central regions
    of the United States (principally Oklahoma,
    Kansas, and North Texas), usually having
    characteristics between those of Pennsylvania
    and coastal oils.
    Middle Distillate
    One of the distillates obtained between
    kerosene and lubricating oil fractions in the
    refining processes. These include light fuel oils
    and diesel fuel.
    MIL Spec
    Military specification; a guide in determining the
    quality requirements of products used by the
    military services, published by the United States
    Department of Defense.
    Motor Method - Motor Octane
    Number (MON)
    A test for determining the knock rating, in terms
    of ASTM Motor Octane Numbers, of fuels for
    use in spark-ignition engines. The knocking
    tendency of the fuel is compared with those for
    blends of reference fuels of known octane
    number when run in the ASTM-CFR engine at
    900 rpm, under standard operating conditions
    as prescribed in ASTM Method D 357.
    MSDS
    Material Safety Data Sheet
    MTAC
    Multiple Test Acceptance Criteria
    Multigrade Oil
    One of the multiviscosity number oils in which
    one oil combines three SAE viscosity number
    grades. For example, multigrade SAE 10W-40
    grade may be used where SAE 10W, SAE 20W,
    SAE 20, SAE 30, or SAE 40 grades are
    specified. They have been made possible by
    improved refining processes and the use of
    polymer additives.
    Multipurpose Grease
    A lubricating grease suitable to meet the
    individual requirements for chassis lubricant,
    bearing lubricant, joint lubricant, water-pump
    lubricant and cup grease.
    MVMA
    Motor Vehicle Manufacturers Association
  14. #11
    N
    NAFTA
    North America Free Trade Agreement
    Naphthene
    One of a group of cycle hydrocarbons, also
    termed cycloparaffins or cycloalkanes.
    Polycyclic members are also found in the higher
    boiling fractions. The general formula for
    naphthenes is CnH2n.
    Neutralization Number
    The weight, in milligrams, of potassium
    hydroxide needed to neutralize the acid in 1g
    of oil. The neutralization number of an oil is an
    indication of its acidity.
    Neutral Oil
    Light overhead cuts of lubricant stocks. Neutral
    oils are the basis for most commonly used
    automotive lubricants.
    NLGI Number
    One of a series of numbers classifying the
    consistency range of lubricating greases, based
    on the ASTM cone penetration number. The
    National Lubricating Grease Institute (NLGI)
    grades are in order of increasing consistency
    (hardness).
    NMMA
    National Marine Manufacturers Association
    NVMA
    National Vehicle Manufacturers Association
  16. #12
    O
    Octane Number
    A term numerically indicating the relative
    antiknock value of a gasoline. For octane
    numbers 100 or below, it is based upon a
    comparison with the reference fuels isooctane
    (100 octane number) and n-heptane (0 octane
    number). The octane number of an unknown
    fuel is the percent by volume of isooctane with
    n-heptane which matches the unknown fuel in
    knocking tendencies under a specified set of
    conditions. Above 100, the octane number of a
    fuel is based on the engine rating, in terms of
    milliliters of tetraethyllead in isooctane which
    matches that of the unknown fuel.
    OECD
    Organization Economic Cooperation and
    Development
    OEM
    Original Equipment Manufacturer
    Oil Groove
    One of the shallow grooves cut into the rubbing
    faces of a bearing shell to improve the
    distribution of oil over the shaft and bearings.
    The grooves are connected with an oil supply
    hole or cup and act like ducts in conveying the
    oil to the various parts of the bearings.
    Oil Ring
    1. A loose ring, the inner surface of which rides
    a shaft or journal causing the ring to rotate. The
    ring dips into the reservoir of lubricant, from
    which it carries the lubricant to the top of the
    shaft for distribution to a bearing. 2. This is the
    ring on an internal-combustion engine piston
    controls the lubrication of the piston and cylinder
    walls, as contrasted to the compression ring.
    Oiliness
    1. That characteristic of a liquid which is
    responsible for the degree of friction between
    two surfaces which cannot be accounted for on
    the basis of viscosity alone. 2 The ability of a
    lubricating oil to orient itself on bearing surfaces
    so as to form new surfaces with a low coefficient
    of static friction.
    OLAP
    Oil Labeling Assessment Program
    ORI
    Octane Requirement Increase
  1. NFPA Glossary of Terms 2013
    By Marty Thompson in forum Safety And Environment
    Last Post: 10-09-2013, 04:20 PM
  2. Article: Glossary of HSE Terms
    By f81aa in forum Home Articles
    Last Post: 04-14-2013, 12:22 AM
  3. Glossary of HSE Terms
    By f81aa in forum Safety And Environment
    Last Post: 04-08-2013, 06:34 AM
  4. Functional Safety Terms and Acronyms Glossary
    Last Post: 04-08-2013, 06:32 AM
  5. CCPS - Combined Glossary of Terms
    Last Post: 01-22-2010, 09:31 PM
