Results 1 to 5 of 5
Thread: pump performance curves.
    Dear All,
    in pump performance curves (attached file), I do not know how min flow was establised or caculated? and second, in some handbook of pump, I see the shape of brake horsepower line is the same as efficiency line. but in this pump, It's the straight line leaning from left to right.
    someone gives me a hand?
    Re: pump performance curves.
    1. If you examine the graph you have:
    process load characteristic (a straith line) that gives the operating point for the pump at diferents speeds( for example:
    Q=420 Nm3/h, Head=75m, Efficiency=80% Speed=603 rpm Power=4x25=60kW
    2. Minflow - is done by the left straight line Qmin=130 nm3/h at speed=603 rpm and at minimum speed=457 rpm is 97 Nm3/h.
    thank for reply. but according to curve, you can see that 603mm and 407mm are the impeller diameters. not speed of pump
    Trying to clarify the previous answer, you have the minimum impeller diameter in 457 mm, and maximum impeller diameter in 603 mm.
    You can see the Minflow line as a straight line (this is so because the relationship between impeller diameter and flow is linear) it starts at
    ~ 90 m3/h and finish at ~ 130 m3/h.
    The power line is not so clear, but you can multiply flow x DP and divide by efficiency using consistent units.
    I hope this help you.
    At 603 impeller dia the min flow is 130m^3/hr
    At 530 impeller dia the min flow is 110m^3/hr
    At 521impeller dia the min flow is 107m^3/hr
    At 457 impeller dia the min flow is 95m^3/hr
    Hope to have clarified you.
  1. Cooling Tower Institute Performance Curves BOOK(CTI BLUE Book)
    By arnab in forum Mechanical Engineering
    Last Post: 09-26-2018, 08:45 PM
  2. Centrifugal Pump Performance Curve
    By Khurram Rehman in forum Mechanical Engineering
    Last Post: 03-26-2014, 05:02 PM
  3. The Interaction Between Geometry and Performance of a Centrifugal Pump
    By insult2injury in forum Mechanical Engineering
    Last Post: 09-04-2013, 11:02 AM
  4. pump performance prediction
    By bmshah in forum Mechanical Engineering
    Last Post: 09-04-2013, 11:00 AM
  5. [Plz Urgently Needed] Electrical submersible Pump Performance examples
    By abdulasad in forum Oil And Gas Production
    Last Post: 11-12-2012, 09:01 PM
