Thread: Tube to Tubesheet joint effect on Tubesheet thickness
  1. Tube to Tubesheet joint effect on Tubesheet thickness
    Hi,
    I have gone through UHX but can not find the effect of tube to tubesheet joint type on tubesheet thickness calculation.
    In one case I've checked below results with software:
    Expanded only, expanded with 1 groove, expanded with 2 groove: same result for 3 cases 143mm
    Welded (all methods including a>1.4t, t<a<1.4t): 161
    Welded and expanded (all possible combination): 143
    I have below questions:
    1- How the joint type (weld or expand) affect the calculation? where in UHX it is clarified?
    2- When we have "Strength welded plus lightly expanded" :
    2-1- What is the sequence?
    2-2- What is the difference between lightly expanded and expanded? Is the difference just about tube wall thinning or existence of grooves govern the identification?
    2-3- Can we consider this as "welded and expanded" or it's just "welded" and expanding is not participating in load carrying?
    Any comments and discussion is highly appreciated.
  3. Re: Tube to Tubesheet joint effect on Tubesheet thickness
    Any knowledge sharing????????
  1. Tube to tubesheet leakage in shell & tube heat exchangers
    By amitss_sam in forum Mechanical Engineering
    Last Post: 03-16-2016, 08:10 AM
  2. Replies: 0
    Last Post: 08-25-2013, 01:18 AM
  3. Replies: 1
    Last Post: 01-31-2012, 09:03 AM
  4. Replies: 1
    Last Post: 12-11-2010, 11:36 PM
  5. DPT - TUBE to TUBESHEET JOINT
    By r_rajesh82 in forum Mechanical Engineering
    Last Post: 08-08-2010, 07:09 PM
