Thread: ASTM A335 P22 vs 12Cr1MoVG
  1. ASTM A335 P22 vs 12Cr1MoVG
    Hi there,
    Right now I'm supervising in designing of Steam Coal Power Plant. Based on our requirement, main steam pipe shall use ASTM A335 P22 material.
    The contractor proposed 12Cr1MoVG for main steam pipe instead of our requirement.
    Right now, we are debating about this material. We are debating about which one is better for main steam pipe.
    Could some one help us to give the comparisson of those material ? Could you give an advice, which material is better for the main steam pipe ?
    For information, temperature that will pass through the main steam pipe is around 500 C.
    Thanks in advanced
    Mar 2011
    Bontang, Kalimantan Timur, Indonesia, Indonesia
    Re: ASTM A335 P22 vs 12Cr1MoVG
    In our plant using 12Cr1Mov as our HP superheater tube, but for main HP header using P22. For HP piping using P11. Temperature 510degC
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM A262, ASTM G108 ASTM A923 are required
    By mohammed21 in forum Mechanical Engineering
    Last Post: 12-13-2014, 07:21 AM
  4. Replies: 2
    Last Post: 04-21-2013, 10:30 AM
  5. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
