Thread: ASME B31.3 Piping code tee
    I need some help about an integral reinforced tee. Pipe material is AISI 304 thickness 3 mm. By calculation I need a reinforce having a thickness at least = 7 mm. I was thinking to weld a plate (integral reinforce) of AISI 347.
    Is that vision correct?
    Thanks in advance
  3. Re: ASME B31.3 Piping code tee
    Why use a 347 plate for a 304 pipe?
    Regarding your calcs, review B31.3 para 304.3 for the design methods.
  1. Code Case 2695 and ASME 2010 Code Cases
    By mbc.engg in forum Mechanical Engineering
    Last Post: 05-13-2016, 11:10 AM
  2. Applying the ASME Code: Plant Piping and Pressure Vessels
    By Noppakhun in forum Mechanical Engineering
    Last Post: 06-21-2014, 06:42 AM
  3. Replies: 0
    Last Post: 03-13-2014, 06:31 PM
  4. Piping Systems & Pipeline: ASME Code Simplified
    By himanshu in forum Pipeline And Fluid Flow
    Last Post: 08-13-2011, 05:15 PM
  5. Piping Systems & Pipeline: ASME Code Simplified
    By sharmeen in forum Pipeline And Fluid Flow
    Last Post: 11-27-2009, 09:32 PM
