Thread: Hysys
    Hysys
    How to enter relative humidity into hysys for air injection?
    Jan 2009
    somewhere on the earth
    Re: Hysys
    Dear bzeng
    You should use Psychometric Charts to find (kg H2O)/ (kg Air), you can determine this ratio by 2 known parameter of "Dry Bulb Temp, Wet Bulb Temp, Relative Humidity, Humidity Ratio and Enthalpy". The below site explains how to obtain the desired parameter from psychometric charts:
    or simply use the uploaded G&P software:
    Then go to the composition tab in HYSYS and change basis into "Mass Fraction" and enter the proper fraction which obtained from the charts or software.
    Good Luck
