Thread: SIL Certification?
  1. SIL Certification?
    Do we need Components SIL Certification? The standard IEC 61508 does not ask for this. I think the certification has to be at system level for the complete SIS for a specific SIF.
  3. Re: SIL Certification?
    Hi, no you don't need a specific SIL level for components. As you said nor IEC-61508 or IEC-61511 (ISA 84) require this, using SIL rated component gives you an advantage as the calculation for the verification phase are easier. Remember the SIL level is for all the SIF, so you may have a SIL 3 logic solver and a SIL 3 transmitter, but if you have a SIL 1 Final Control Element you will have a SIL 1 SIF. The only way to improve the SIL rating would be putting ridiculous maintenance schemes. The other way of claiming a SIL level for a SIF with no SIL rated component would be using proven in use data, but you would have to be specific for the aplication, for example you can't claim proven in use for a pressure transmitter in the O&G industry if you have data for a food factory or so.
  1. SPE Certification
    By akhmadiev_ruslan in forum Engineering Certificates
    Last Post: 01-31-2014, 08:40 PM
  2. API 936 certification
    By kenil in forum Mechanical Engineering
    Last Post: 08-08-2013, 06:35 AM
  3. PMI Certification
    By frankblack in forum Planning & Project Management
    Last Post: 05-22-2013, 01:51 PM
  4. PMI certification
    By saurabhkumarsaxena in forum Instrumentation & Control
    Last Post: 10-19-2011, 08:05 PM
  5. Reg:Certification
    By youngpiper in forum Pipeline And Fluid Flow
    Last Post: 09-28-2010, 03:19 PM
