Thread: Firewater deluge system velocity limit for titanium
  1. Firewater deluge system velocity limit for titanium
    Hi,
    could any of you advise on what is the max. velocity limit for titanium piping used in firewater deluge system (downstream od deluge valve). My experience is that this is typically below the erosional velocity of the piping material used, and that NFPA15 & 16 does not set a velocity limit on deluge system too.
    Norsok P-001 does provide limit for titanium at 7m/s , and it indicated a velocity limit of 10m/s is allow for intermittent service. It also indicated that BS MA-18 is to be referred to for pipe size smaller than (DN200) 8inch.
    Would greatly appreciate if someone could share a copy of BS MA-18 Specification for salt water piping systems in ships
    Re: Firewater deluge system velocity limit for titanium
    you can download it at scribd:
  1. Fireproofing of firewater system pipe support???
    By Techsafety in forum Safety And Environment
    Last Post: 04-17-2014, 07:18 AM
  2. Article: firewater system design with pipephase
    By aderemi in forum Home Articles
    Last Post: 08-26-2012, 11:38 PM
  3. firewater system design with pipephase
    By aderemi in forum Oil And Gas Process
    Last Post: 08-15-2012, 05:59 PM
  4. Request for limit load or limit analysis paper for offshore pipeline
    By nicholasheng in forum Pipeline And Fluid Flow
    Last Post: 04-09-2010, 08:59 AM
  5. fireproofing for dry type deluge and spray system
    By khalid20045 in forum Safety And Environment
    Last Post: 04-08-2010, 08:37 AM
