Thread: Request: cooling load calculations
    hi friends
    i need a spreadsheet or the methodology for cooling load calculation as well as heat load calculation for calculating the tonnage of a/c required.
  3. Re: Request: cooling load calculations
    Hello,
    As per my knowledge, the formula for calculating AC load= Length(mtrs) x Width(mtrs) x 173.66 (units: Watts of Refrigeration), you can convert this into kcal/hr and then Tonn of Refrigereation.
    For kitchen you can consider 2000 watt of refrigeration.
    Thanks & Regards
    Raman
  1. Allowable nozzle load calculations
    By kishor in forum Mechanical Engineering
    Last Post: 07-30-2014, 02:19 PM
  2. Request : excel calculations for LPG calculations as per 11.2.4
    By STEVEBD in forum Laboratory Measurements
    Last Post: 08-19-2013, 10:30 AM
  3. Cooling load calculation software
    By DOKUNDOT in forum Mechanical Engineering
    Last Post: 05-22-2013, 03:38 PM
  4. HVAC Cooling Load Calculation Software
    By arunima04 in forum Mechanical Engineering
    Last Post: 07-05-2010, 08:25 AM
  5. Request for limit load or limit analysis paper for offshore pipeline
    By nicholasheng in forum Pipeline And Fluid Flow
    Last Post: 04-09-2010, 08:59 AM
