Results 1 to 8 of 8
Thread: flange selection
  1. flange selection
    how the flange thickness is decide
    Re: flange selection
    Do you refer to welded-neck flange where the thickness of neck should be the same as for piping?
    Quote Originally Posted by milind25 View Post
    depend of the pressure that you are working. With this pressure, you have to use Asme b16.5, and choice the rating, with this rating, you get the thickness of the flange.
    (sorry by my English)
    Enviado desde mi GT-I9300 usando Tapatalk 2
    I think the difficulty to answer is because a flange is a complex body having more than one thickness.
    "B16.5" flanges are following ASME B16.5 Code where dimensions are given in tables versus size and pressure rating; neck thickness need not be more that those corresponding to pipe/ piping class.
    Special flanges must be calculated considering specialized codes as ASME VIII Div 1 or 2- for example.
    I think you shall decide first which standard you are following; ASME standards (B16.5 for sizes up to 24" and B16.47 for more than 24") or Euopean standards, because there is a difference between them espcially for large sizes.
    This has been decided based on the type of valve or equipments you need to connect with your piping system and according to you system pressure requirements.
    finally after deciding your standard you'll find all required detail for dimensions, thickness and No. of Bolts in each one.
  9. Re: flange selection
    thank you sir
    Jul 2008
    malaysia
    Blog Entries
    2
    apart from B16.5, ASME Sect 8 Div 1 have design procedure in defining falnge design as per Appendix 1-7 (for Large Diameter Flange). It will defined the flange thickness and dimensional parameter , Bolting requirement , Gasket selection. Dimensional parameter is first selected as per B16.5 for references before full analysis can be performed.
    In fact different codes of standard flange is vary from one another. we have B16.5, B1.47-A & B (LARGE DIAMETER), API, JIS, AWWA
    do have a quick look on this standard oil and gas flange
  11. Re: flange selection
    the guy doesnt even know what he's asking, nor what he needs.
  1. Din flange std
    By sakesit in forum Mechanical Engineering
    Last Post: 07-05-2018, 11:25 PM
  2. API flange vs ASME flange
    By aap in forum Mechanical Engineering
    Last Post: 07-09-2013, 12:34 AM
  3. DIN flange
    By bamuti in forum Pipeline And Fluid Flow
    Last Post: 07-02-2013, 02:29 PM
  4. selection of flange material
    By sumon emam in forum Materials Science &Corrosion
    Last Post: 02-04-2011, 11:08 AM
  5. Flange Weight
    By liewnh in forum Mechanical Engineering
    Last Post: 09-23-2010, 04:58 AM
