Any body knows compared to 44th ed. ?
New ANSI/API Spec 5L 45th Edition released – Specification for Line Pipe
The new ANSI/API Specification 5L 45th Edition, “Specification for Line Pipe,” was released 12/2012 and is now available from Document Center Inc. This Standard specifies requirements for the manufacture of two product specification levels (PSL 1 and PSL 2) of seamless and welded steel pipes for use in pipeline transportation systems in the petroleum and natural gas industries.
This new revision was generated in order to strengthen requirements to ensure quality, reduce potential for non-conforming pipe and provide improved tools for communication between manufacturer and purchaser.
A summary of some of the key requirements are:
- Enhanced requirements for selection and qualification raw material suppliers (plate and coil),
- Increased frequency for tests of mechanical properties,
- An allowance for digital radiography in lieu of film,
- Identification and validation of critical variables throughout all manufacturing processes (steel melting, plate/coil rolling, pipe forming, etc.) to assure suitable mechanical properties, and
- Additional re-test requirements in case of tensile test failure.
Most of the changes to the 45th Edition of API Specification 5L were made to incorporate the requirements from the previously published Errata/Addenda into the main specification.
In addition, changes were made to Section 11.4, Marking of pipe to multiple grades.
API Standards can be purchased from Document Center Inc. at our webstore,[link Point to another website Only the registered members can access]
Thank you for good info.
Dear My Friends
and one have the API Spec 5L 45th Edition, please share the link? Thanks
Dear My Friends
5L 45th split in 2 parts
Dear Marty, please upload again because the link doesn't work, thank you
Dear Marty
yes the link doesn't work? please resend
Dear Marty
Now split in 2 parts above
Thank you !
