Good day,
I am currently doing some pre-work where I will be required to write set point values to controllers via OPC. The DCS in question is a Honeywell TDC3000 and for the OPC Client, I am using Matrikon OPC Mobile. I manage to connect to the OPC Server (TPNServer in this instance) and all the tags can be browsed and valued read.
I have enabled "Full Control" on all the HPM and associated devices on the UCN. I am also able to write values to Numeric blocks, change tuning parameters etc. Where I am stuck however, is changing the parameters (.SP & .OP) of the regulatory control blocks. I have put the PID block in Program mode - Auto, tried every permutation of remote set point sourcing, but to no avail, I cannot write a SP via OPC.
Any ideas of how to proceed?
