Results 1 to 5 of 5
Thread: Air Conditioning Calculation .xls sheet
    Find attached the .xls sheet, for Air Conditioning System-Heat Load Calculation.... This is by manual process... I have used it for some projects... It will give a idea about the factor which affecting heat load....
    Attached Files Attached Files
    Re: Air Conditioning Calculation .xls sheet
    Muhammad Khurram
    Thanks. I have something similar.
    See attachment.
    Thanks Mr. DOKUNDOT....
    I have one query: How will calculate the climate condition for the location which are not listed in ASHRAE....
    mk.chy12,
    If you check, you can edit the weather conditions to match that for your location. Use a nearby region that closely matches yours. Within the margin of error, you should be ok.
  1. API 620-Thickness Calculation-Excel Sheet
    By qwerasd in forum Oil And Gas Production
    Last Post: 09-03-2013, 08:12 PM
  2. annular velocity calculation sheet
    By arungnanam88 in forum Petroleum Refining
    Last Post: 09-02-2013, 04:07 PM
  3. Voltage drop calculation spread sheet
    By cag in forum Electrical & Power Engineering
    Last Post: 02-23-2013, 02:02 PM
  4. Anode Size Calculation Excel Sheet
    By mbc.engg in forum Mechanical Engineering
    Last Post: 12-19-2012, 07:24 AM
  5. Blowers and Fans Calculation sheet with formula
    By ayush842001 in forum Mechanical Engineering
    Last Post: 08-05-2011, 07:24 AM
