understanding steam and steam traps. Here you can find two fine e-books and one ppt. presentiation on steam traps. Hopefully you will find it useful. Some introduction about these books. These Books are published by Spirax Sarco.
Section 1: System Design Information....................................... ..................1
The Working Pressure in the Boiler and the Mains.........2
Sizing Steam Lines on Velocity.........3
Steam Pipe Sizing for Pressure Drop.................5
Sizing Superheated Mains......6
Properties of Saturated Steam ............7
Draining Steam Mains .............8
Steam Tracing ...................................12
Pressure Reducing Stations .............19
Parallel and Series Operation of Reducing Valves ............21
How to Size Temperature and Pressure Control Valves ...............23
Temperature Control Valves for Steam Service ................26
Temperature Control Valves for Liquid Service..........28
Makeup Air Heating Coils ..............31
Draining Temperature Controlled Steam Equipment .............33
Multi-Coil Heaters ............................36
Steam Trap Selection.......................38
Flash Steam.......................................41
Condensate Recovery Systems ...........45
Condensate Pumping ..........................48
Clean Steam ...................................50
Testing Steam Traps.............................55
Spira-tec Trap Leak Detector Systems for Checking Steam Traps..........58
Steam Meters...................................59
Compressed Air Systems ..............62
Reference Charts and Tables ...................................66
Section 2: Hook-up Application Diagrams.............83
For Diagram Content, please refer to Subject Index on page 149.
Section 3: Product Information ...............143
An overview of the Spirax Sarco Product Line
BASIC STEAM ENGINEERING PRINCIPLES
INTRODUCTION 6
WHAT IS STEAM 6
STEAM GENERATION 10
BOILERS & BOILER EFFICIENCY 10
SELECTION OF WORKING PRESSURES 11
STEAM SYSTEM BASICS 14
STEAM AND CONDENSATE METERING 17
Costing and Custody Transfer 18
CONTROL AND REGULATION OF STEAM 19
STEAM TRAPS AND THE REMOVAL OF CONDENSATE 26
STEAM TRAPS 27
STEAM TRAP TESTING METHODS 37
BY-PASSES AROUND STEAM TRAPS 39
PREVENTIVE MAINTENANCE PROGRAMS 39
Steam Trap Fault Finding 39
Steam Trap Discharge Characteristics 41
STEAM TRAP SELECTION 41
Waterlogging 41
Lifting of Condensate 42
REQUIREMENTS FOR STEAM TRAP/APPLICATIONS 42
Application Requirements 42
Steam Trap Selection Chart 43
Steam Trap Sizing 44
STEAM TRACING 45
CONDENSATE MANAGEMENT 50
Also included an excellet power point presentation on Steam Traps.
Hopefully you will find it very useful.
Thankyou
