Thread: Sphere or Tanks???
  1. Question Sphere or Tanks???
    Hi Everyone,
    Can anyone explain how to choose between a sphere or tank when selecting storage vessel type for a service?
    Also, how to select between internal floating roof and floating roof or dome shaped tanks?
    Thanks,
  3. Re: Sphere or Tanks???
    Spheres are also tanks.I think you mean Spherical tanks or Cylindrical tanks.If so:Spherical tanks have more storage volume than cylindrical for the same surface area.For high pressure storage spherical tanks are chosen.But for very large tanks cylindrical is the choice.Because spheres are difficult to construct.
    Sphere is for pressurized storage. Spherical shape is an advantage to reduce stress in shell. However keeping allowable stress (and looking to market availability of thickness) means to limit the diameter of sphere, hence the capacity is limited.
    Tank cannot be designed for large pressure, but for moderate pressures- let's say around 200 mbarg.
    For example you can deposit LPG in spheres- 3000 or 4000cum, under pressure at atmospheric temperatures, or in you have to refrigerate LPG and keep it in 50000 cum tanks under low pressure.
    Tank's roof of dome shape respond positively to internal pressure, especially such shape assures a reasonable thickness for "compression ring/compression bar" - in fact these words describe the junction "roof to shell". Larger tangent-to roof angle at periphery is an advantage to keep there the thickness at 20-50mm; for dome the peripheral angle is around 30 degree, for cone roof type cannot be so large.
    External floating roof means "free space" above floating roof. Internal floating roof means there is space over the floating roof and beneath the roof (dome, umbrella or cone) that can be pressurized (let's say blanketing for limiting vaporization).
  1. Request: LPG sphere
    Last Post: 11-22-2011, 08:37 PM
  2. Horton sphere construction
    By cathweld in forum Mechanical Engineering
    Last Post: 07-26-2011, 05:10 PM
  3. LPG sphere maximum diferential settlements!!!
    By mave in forum Mechanical Engineering
    Last Post: 11-26-2010, 06:15 PM
  4. Sphere Design
    By sameercnn in forum Mechanical Engineering
    Last Post: 09-14-2010, 04:55 AM
  5. piping & instrumentation diagram for lpg sphere
    By ananks3 in forum Instrumentation & Control
    Last Post: 03-02-2009, 08:05 AM
