Can anybody assist by referral to a document, code and standard that give clear information for the calculation of Fire Water Demand for the Process Area
Try to find this book
Fire Fighting Pumping Systems At Industrial Facilities Nolan
Greetings
Abo Khaled
All is defined on NFPA 750 standard and other specific nfpa standards. Easy: Calculate the amount of water requided for extingish the fire in 2 hours (NFPA) for Each specific area that you want to protect. The water fire tank must be designed to have a minimum capacity for 2 hours and 8h for recover again the level of water (2 hours of operation).
Thanks a lot for the good suggestion
you find here hxxp://www.libgen.info/view.php?id=584312
Thanks Good information.
regards
