Can anybody help...
I need to undertake the desing of a trunnion. The pipe is designed to ASME B31.1. Is there any codes I can use to complete my design.
Can anybody help...
DIN 28085,[link Point to another website Only the registered members can access]
If B31.1 is your Code, you should use that Code to satisfy your design Code requirement.
The design thus has to meet the requirements of B31.1.
There are different approaches to designing a trunnion. Get some piping handbooks and should get a first rough idea where to start.
If your design Cade is B31.1 then you must comply with the requirements of this Code. A procedure for the design of trunnions is given in an ASME Code Case. From Memory it is N318 I think. This is basically where the procedure in the EN Piping Code came from.
