Hi all
I am looking for API 934-E Ed. 1 (2010) Recommended Practice For Materials And Fabrication Of 1[1/4]Cr-[1/2]Mo Steel Pressure Vessels For Service Above 825 Degrees F (440 Degrees C)
Can anyone help me?
Thanks you..
Hi all
Can anyone help me?
Thanks you..
Does anyone have this code?
Cheers!!
Here you go...
Marty,
You are a legend. Anything you are after?
These are some of the latest issued or updated in 2014 and 2015 if you could get any, it would help some here.
RP 584, RP 585, Spec 11AX, RP 19G9, RP 2N, Spec 11D1,
RP 2MOP, Std 530, Std 660, Spec 16C, MPMS 10.4,
RP 17R, TR 17TR12, STD 520 P2, TR 17TR8, RP 1168,
MPMS 4.2, RP 17U, Std 600, Spec 14A, RP 2EQ, RP 2MET,
RP 2SIM, Std 670, RP 13J, RP 2GEO, Spec 12B, RP 3000,
RP 756, TR 756-1, MPMS 2.2G, RP 2SM, RP 5L3, Std 612,
Std 17O, Std 520P1, Bull 100-3, MPMS 4.5, RP 8C, Std 17F,
Std 2015, RP 17B, Spec 17J, Std 663
The only one i have is 600, Is it possible for you to send me a private message on here?
The 600-2015 has already been shared here, this list was from 2 weeks ago. Thanks
These are the refining publications that I have not seen shared yet
API Standard 520, Part 2
Sizing, Selection, and Installation of Pressure-relieving Devices, Part II—Installation, Sixth Edition, March 2015
API Standard 530
Calculation of Heater-tube Thickness in Petroleum Refineries, Seventh Edition, April 2015
API Standard 541
Form-wound Squirrel Cage Induction Motors—375 kW (500 Horsepower) and Larger, Fifth Edition, December 2014
API Standard 602
Gate, Globe, and Check Valves for Sizes DN 100 (NPS 4) and Smaller for the Petroleum and Natural Gas Industries, Tenth Edition, May 2015
API Standard 617
Axial and Centrifugal Compressors and Expander-compressors, Eighth Edition, September 2014
API Standard 660
Shell-and-Tube Heat Exchangers, Ninth Edition, March 2015
API Standard 670
Machinery Protection Systems, Fifth Edition, November 2014
API Recommended Practice 756
Management of Hazards Associated with Location of Process Plant Tents, First Edition, September 2014
API Technical Report 756-1
Process Plant Tent Responses to Vapor Cloud Explosions—Results of the American Petroleum Institute Tent Testing Program, First Edition, September 2014
API Technical Report 938-C
Use of Duplex Stainless Steels in the Oil Refining Industry, Third Edition, February 2015
These are the New Safety, Fire and Scientific Affairs Publications that I have not seen yet
API Standard 2015
Requirements for Safe Entry and Cleaning of Petroleum Storage Tanks, Seventh Edition, May 2014
API Recommended Practice 2030
Application of Fixed Water Spray Systems for Fire Protection in the Petroleum and Petrochemical Industries, Fourth Edition, September 2014
This New Transportation Publication is missing
ANSI/API Recommended Practice 3000
Classifying and Loading of Crude Oil into Rail Tank Cars, First Edition, September 2014
Correct Mark. Some of the ones you mention are typical API's Id like see being shared too.
These New Exploration and Production Publications have not been seen
API Recommended Practice 2D
Operation and Maintenance of Offshore Cranes, Seventh Edition, December 2014
ANSI/API Recommended Practice 2EQ/ISO 19901-2
Seismic Design Procedures and Criteria for Offshore Structures, First Edition, November 2014
ANSI/API Recommended Practice 2MET/ISO 19901-1
Derivation of Metocean Design and Operating Conditions, First Edition, November 2014
API Recommended Practice 2N/ISO 19906
Planning, Designing, and Constructing Structures and Pipelines for Arctic Conditions, Third Edition, April 2015
API Recommended Practice 2SIM
Structural Integrity Management of Fixed Offshore Structures, First Edition, November 2014
API Recommended Practice 5L3
Drop-Weight Tear Tests on Line Pipe, Fourth Edition, August 2014
API Specification 5LC
CRA Line Pipe, Fourth Edition, March 2015
API Specification 5LD
CRA Clad or Lined Steel Pipe, Fourth Edition, March 2015
API Standard 7CW
Casing Wear Tests, First Edition, June 2015
API Specification 11AX
Specification for Subsurface Sucker Rod Pump Assemblies, Components, and Fittings, Thirteenth Edition, May 2015
API Specification 11D1
Packers and Bridge Plugs, Third Edition, April, 2015
API Specification 12B
Specification for Bolted Tanks for Storage of Production Liquids, Sixteenth Edition, November 2014
API Recommended Practice 13C
Recommended Practice on Drilling Fluid Processing Systems Evaluation, Fifth Edition, October 2014
API Recommended Practice 13J
Testing of Heavy Brines, Fifth Edition, October 2014
API Specification 14A
Subsurface Safety Valve Equipment, Twelfth Edition, January 2015
API Specification 16C
Choke and Kill Equipment, Second Edition, March 2015
API Recommended Practice 17R
Recommended Practice for Flowline Connectors and Jumpers, First Edition, March 2015
API Recommended Practice 17S
Recommended Practice for the Design, Testing, and Operation of Subsea Multiphase Flow Meters, First Edition, June 2015
API Technical Report 17TR8
High-pressure High-temperature Design Guidelines, First Edition, February 2015
API Technical Report 17TR12
Consideration of External Pressure in the Design and Pressure Rating of Subsea Equipment, First Edition, March 2015
API Recommended Practice 17U
Recommended Practice for Wet and Dry Thermal Insulation of Subsea Flowlines and Equipment, First Edition, February 2015
API Recommended Practice 17V
Recommended Practice for Analysis, Design, Installation, and Testing of Safety Systems for Subsea Applications, First Edition, February 2015
API Recommended Practice 19G9
Design, Operation, and Troubleshooting of Dual Gas-lift Wells, Second Edition, April 2015
These New Manual of Petroleum Measurement Publications have not been seen
API MPMS Chapter 2.2G
Calibration of Upright Cylindrical Tanks Using the Total Station Reference Line Method, First Edition, July 2014
ANSI/API MPMS Chapter 7.5/ISO 8310:2012
Temperature Determination—Automatic Tank Temperature Measurement Onboard Marine Vessels Carrying Refrigerated Hydrocarbon and Chemical Gas Fluids, First Edition, September 2014
API MPMS Chapter 8.1
Standard Practice for Manual Sampling of Petroleum and Petroleum Products, Fourth Edition, October 2013
API MPMS Chapter 8.4
Standard Practice for Sampling and Handling of Fuels for Volatility Measurement, Third Edition, March 2014
API MPMS Chapter 10.4
Determination of Water and/or Sediment in Crude Oil by the Centrifuge Method (Field Procedure), Fourth Edition, October 2013
API MPMS Chapter 14.3.3
Orifice Metering of Natural Gas and Other Related Hydrocarbon Fluids—Concentric, Square-edged Orifice Meters, Part 3: Natural Gas Applications, Fourth Edition, November 2013
API MPMS Chapter 17.1
Guidelines for Marine Inspection, Sixth Edition, June 2014
API MPMS Chapter 17.6
Guidelines for Determining the Fullness of Pipelines Between Vessels and Shore Tanks, Second Edition, June 2014
API MPMS Chapter 17.10.1
Measurement of Cargoes on Board Marine Gas Carriers, Part 1—Liquefied Natural Gas, First Edition, April 2014
API Technical Report 2575
Measurement of Thermally *****ed Gas, First Edition, September 2014
