Thread: Material balance in tight reservoir
    hi any body can explain me why material balance is not possible in tight reservoir. if possible what are the equation and logics to carry out material balance.
    Nov 2008
    Australia
    Re: Material balance in tight reservoir
    Think about it. What does simple MB type approaches rely upon? Compressibility, Volume and Pressure
    Compressibility and Volumes are still OK - what about pressure? You have to supply an AVERAGE reservoir pressure - what is the average reservoir pressure in a tight reservoir? In a tight reservoir you'll likely see rapid depletion around a well and interpret that as a very small reservoir volume, yet you'll drill 2 well spacings away and see some minor depletion
    Material balance does work - indeed it is embedded in reservoir simulation calcs - its the assumption that you can easily determine the average reservoir pressure that breaks down in tight reservoirs.
  1. Replies: 3
    Last Post: 07-16-2013, 12:49 PM
  2. Material Balance for Fractured Reservoir
    By zaheer.jamali in forum Reservoir
    Last Post: 08-25-2011, 05:40 AM
  3. Tight gas Reservoir
    By MIROINE in forum Reservoir
    Last Post: 08-07-2011, 01:49 AM
  4. Average Reservoir Pressure in a Material Balance
    By Chee Koh Peh in forum Reservoir
    Last Post: 11-08-2010, 08:29 AM
  5. Tight Gas Reservoir
    By mzakii in forum Reservoir
    Last Post: 05-14-2009, 03:50 PM
