Every 2 wire loop powered HART transmitter has a spec for how much voltage the power supply has to provide in order to overcome the total loop resistance.
Sometimes this is a chart of resistance vs voltage, as shown in the attachment.
Other times it's an equation.
You need to determine the resistance of the copper wire for the run (remember that 1100m distance is 2200m of wire) and add to that the input resistance of the HART analog input module (typically 250 ohms, but it varies from model to model, mfr to mfr.) Then check the chart for your transmitters and see if your power supply has enough voltage to make the grade. If not, increase wire size or boost the power supply voltage.
