ASTM D1250
ASTM D1980
ASTM D1555
plz help me!
ASTM D1250
ASTM D1980
ASTM D1555
plz help me!
Hi ttppcc .
Two months ago I have downloaded free ASTM Standard, but not all. I can not find your request in my ASTM Library. But I want give you a tip, how to get ASTM Standard for free download. Please follow this step :
1. Firstly, please down load this ASTM Index file[link Point to another website Only the registered members can access]
2. From downloaded ASTM Index, find out where is the location of your request . There are Vol 1 - Vol 15
3. Go to Google and type : sipil88ftua.forumotion.com/antara-kawan-f4/astm-standar-ada-yg-butuh-t22 or astm universitas andalas
4. From Google you can find following sentences :
4.1. ASTM Standar, ada yg butuh? or
Translation : Do you need ASTM Standard ?
4.2. Teknik Sipil 88 Universitas Andalas - ASTM Standar, ada yg butuh ...
Translation : Civil Engineering 88 University of Andalas - ASTM Standard, somebody need it
5. Click 4.1 or 4.2 and enjoy download all ASTM Standard if you want
Wassalam
Thank you for your kindness.
Hi Achmad Nur Eddin. Can you please put these files into a single folder and re-upload them again? Thanks a lot in advance.
I am working on a few data points where I need to calculate the corrected API (@ 60F) from an observed API which was taken at a different temperature for crude oil. I also need to calcualte corrected volume as well for which I believe I understand I need the VCF (Volume Correction Factors).
I understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume I" contains Table 5A: Generalized Crude Oils, Correction of Observed API Gravity to API Gravity at 60°F and Table 6A: Generalized Crude Oils, Correction of Volume to 60°F Against API Gravity.
I also understand that "Adjunct to D1250 Petroleum Measurement Tables – Volume X" contains Background, Development, and Computer Documentation and that Volume X actually has the algorithms and equations published for calculating and approximating all of the tables published in the 12 volume Adjunct set.
I don't know how many pages there are to Tables 5A and 6A in Volume 1 but that is what I believe I need. Even better would be the algorithms/equations that generate these particular tables for which I understand is published in Volume 10.
Can someone help me with this??
I only need this data for a one time set of calculations..
Thanks to whoever can help me with this!!
Greg
hi ghartman, do you mean that you need function to produce caculation for tab5a and tab6a?
