Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: How to fix the following Eclipse 100 errors?
  1. How to fix the following Eclipse 100 errors?
    @-- error at time 0.0 days ( 1-jan-1997):
    @ insufficient data to compute pore volumes
    @ pore volumes will be set to zero
    @ insufficient data to compute cell centre depths
    @ insufficient data to compute x transmissibilities
    @ insufficient data to compute y transmissibilities
    @ insufficient data to compute z transmissibilities
    @--comment at time 0.0 days ( 1-jan-1997):
    1) Why eclipse doesn't calculate pore volume? I have correctly provided cell porosity and its DX,DY, and DZ dimensions. But it still shows an error .
    2) What is needed to calculate center depth? Does Eclipse do it automatically?
    3) How transmissibility should be calculated? Do I need to do it manually?
    Thanks.
    Re: How to fix the following Eclipse 100 errors?
    - Did you provide NTG?, it's required for both pore vol and transmissibility calculations.
    - Are you using an extremely high value of MINPV so that you are deactivating the whole model?
    - Check your ACTNUM keyword to make sure you are deactivating the right cells.
    Check this.
    - Eclipse does this internally once input data is correctly provided.
    Let us take a look of your *.data file to check it.
  5. Re: How to fix the following Eclipse 100 errors?
    Quote Originally Posted by DAH7542 View Post
    Check this.
    Actually i entered pore volume, PV, as the result of porosity *DX*DY*DZ.
    I have attached my input data in .txt format as Eclipse doesn't accept .data file.
    Attached Files Attached Files
    I found and solved many problems in your run, not only with respect to the global grid and LGR definition but with the Schedule section. It is running without problems now.
  7. Re: How to fix the following Eclipse 100 errors?
    Quote Originally Posted by pet_spec View Post
    Thanks mate for your help.
    Actually, I would like to launch the well for 300 days and to shut it for 200 days then. How can I enter such commands?
    ECLIPSE 300 use different PROPS data than does ECLIPSE 100.
    Moreover, some keywords in SCHEDULE section are also added/changed when u switched to ECLIPSE 300
    Bilal Amjad
    Bilal Amjad
  11. Re: How to fix the following Eclipse 100 errors?
    Quote Originally Posted by 06pg22 View Post
    Yeah ... I know. But I used Eclipse 100 only and manual for it.
    Use the keyword WELOPEN (write it with one "L" only), refer to the ECL reference manual for more details.
  13. Re: How to fix the following Eclipse 100 errors?
    Hello,
    I am unable to download the above attachment. Please help.
  14. Re: How to fix the following Eclipse 100 errors?
    Hello,
  16. #12
    Please I'm having the same problem, can anyone help me out? I'm a beginner in Eclipse.
    @-- ERROR AT TIME 0.0 DAYS (10-AUG-2014):
    @ INSUFFICIENT DATA TO COMPUTE PORE VOLUMES
    @ PORE VOLUMES WILL BE SET TO ZERO
    @ INSUFFICIENT DATA TO COMPUTE CELL CENTRE DEPTHS
    @ INSUFFICIENT DATA TO COMPUTE X TRANSMISSIBILITIES
    @ INSUFFICIENT DATA TO COMPUTE Y TRANSMISSIBILITIES
    @ INSUFFICIENT DATA TO COMPUTE Z TRANSMISSIBILITIES
    @--MESSAGE AT TIME 0.0 DAYS (10-AUG-2014):
    @ NUMBER OF ACTIVE CELLS IS 0
    @ THERE ARE NO ACTIVE CELLS IN THE RESERVOIR
  1. Added wells not showing in eclipse, no errors
    By anonake in forum Reservoir
    Last Post: 05-05-2014, 04:19 PM
  2. Replies: 0
    Last Post: 11-29-2011, 05:18 PM
