Thread: A350 LF2 In Place of A105
    Hi,
    Pipe Class and the data sheet for a ball valve calls for A105 Body material. Project department has procured A350 Lf2 material Ball valve and asking engineering to give some justification to show to client that it is superior and hence acceptable for this service and that guy happens to be me to give this technical justification.
    Could anyone help me in this regard. Thanks in advance.
    Ishaf
    Re: A350 LF2 In Place of A105
    A 350 LF2 is can be used instead A105 cause of same material group if forging valve.
    Get material certificate of the body, get ASTM A105 tables, now show that the values stated in the certificate comply with the parameters demanded by A105.
  1. which is the difference between ASTM A105 grade I y II??
    By waltherc82 in forum Mechanical Engineering
    Last Post: 01-22-2015, 10:44 PM
  2. ASTM A105 and A105N
    By subin in forum Mechanical Engineering
    Last Post: 02-09-2014, 12:18 PM
  3. Using A350/LF2 instead of A105
    By ezat2007 in forum Mechanical Engineering
    Last Post: 01-07-2014, 12:30 PM
  4. ASTM A105 standard request
    By mestcrapp in forum Mechanical Engineering
    Last Post: 03-02-2011, 02:01 PM
