Results 1 to 5 of 5
Thread: Continous, Intermittent and Standby Loads; Demand Factors?
  1. Continous, Intermittent and Standby Loads; Demand Factors?
    Dear Professionals,
    In most oil and gas projects, loads are divided into continuous, intermittent and standby loads; are summed up separately and then applied with 1, 0.5, 0.1 diversity factors for continuous, intermittent and standby respectively. Then,
    maximum running load = continuous loads*(1.0) + intermittent loads*(0.50)
    Peak Load = continuous load*(1.0) + intermittent loads*(0.50) + standby loads*(0.10)
    Are those applied diversity factors: 0.50(for intermittent), 0.10 (for standby) an industry practice? or
    is there a code that recommends these factors?
    Please reply..
    Re: Continous, Intermittent and Standby Loads; Demand Factors?
    The factors are calculated to maintain a probability lower than 95% of the presence of simulataneous load and normally they have two stage: The Ultimate & Serviceabilty limit state design(ULS & SLS). Every code have different factors. But I see that this ones are lower maybe those are SLS.
  5. Re: Continous, Intermittent and Standby Loads; Demand Factors?
    Is (ULS & SLS) one related to electrical..?
    No. This is related to structural loads. The mathematical philosophy of mechanical and electrical system are the same.
    For electrical system you can see this article:
    Sometimes, it depends on the Clients regarding with diversity factors. The higher the diversity factors, the more conservative the design is. And i think it varies from Client to Client.
  1. thesis for designing intermittent gas lift-working model
    By samir in forum Oil And Gas Production
    Last Post: 10-11-2015, 11:26 AM
  2. Replies: 12
    Last Post: 09-02-2014, 10:03 PM
  3. intermittent production from oil well
    By ahmedj9579 in forum Reservoir
    Last Post: 06-26-2013, 11:08 AM
