Good day to you all.
I have one vertical vessel with big diameter (around 8 m) and high weight (around 350 tons). I'm currently designing the saddles for hydrotest and PWHT. The PWHT temperature is 610 °C. For SA-516 Gr.70 the maximum allowable stress is 12.9 MPa °C at 550 °C (considers also creep) and the yield is 158 MPa at 525 °C.
As per my 2 companies experiences, we had never considered this and never faced a problem. But, I'm worried about my current vessel since it is heavy and big in diameter. Shall I design the saddles for hydrotest only, and no need to worry about the PWHT, or do you see that some consideration due to high temperature shall be given?
_________________
M.Salaheldin
