Results 1 to 5 of 5
Thread: Reserve Estimation-Monte Carlo Simulation
    Hello,
    Does anyone have a well-explained document on how to implement "Reserve Estimation-Monte Carlo Simulation."
    Thank you!
    Feb 2010
    Tierra
    Re: Reserve Estimation-Monte Carlo Simulation
    A small article on monte carlo simulation for reserve estimation on web:
    Feb 2010
    Tierra
    For the Beginners :
    How Monte Carlo simulation works
    Monte Carlo simulation performs risk analysis by building models of possible results by substituting a range of values—a probability distribution—for any factor that has inherent uncertainty. It then calculates results over and over, each time using a different set of random values from the probability functions. Depending upon the number of uncertainties and the ranges specified for them, a Monte Carlo simulation could involve thousands or tens of thousands of recalculations before it is complete. Monte Carlo simulation produces distributions of possible outcome values.
    By using probability distributions, variables can have different probabilities of different outcomes occurring. Probability distributions are a much more realistic way of describing uncertainty in variables of a risk analysis. Common probability distributions include:
    Normal – Or “bell curve.” The user simply defines the mean or expected value and a standard deviation to describe the variation about the mean. Values in the middle near the mean are most likely to occur. It is symmetric and describes many natural phenomena such as people’s heights. Examples of variables described by normal distributions include inflation rates and energy prices.
    Lognormal – Values are positively skewed, not symmetric like a normal distribution. It is used to represent values that don’t go below zero but have unlimited positive potential. Examples of variables described by lognormal distributions include real estate property values, stock prices, and oil reserves.
    Uniform – All values have an equal chance of occurring, and the user simply defines the minimum and maximum. Examples of variables that could be uniformly distributed include manufacturing costs or future sales revenues for a new product.
    Triangular – The user defines the minimum, most likely, and maximum values. Values around the most likely are more likely to occur. Variables that could be described by a triangular distribution include past sales history per unit of time and inventory levels.
    PERT- The user defines the minimum, most likely, and maximum values, just like the triangular distribution. Values around the most likely are more likely to occur. However values between the most likely and extremes are more likely to occur than the triangular; that is, the extremes are not as emphasized. An example of the use of a PERT distribution is to describe the duration of a task in a project management model.
    Discrete – The user defines specific values that may occur and the likelihood of each. An example might be the results of a lawsuit: 20% chance of positive verdict, 30% change of negative verdict, 40% chance of settlement, and 10% chance of mistrial.
    During a Monte Carlo simulation, values are sampled at random from the input probability distributions. Each set of samples is called an iteration, and the resulting outcome from that sample is recorded. Monte Carlo simulation does this hundreds or thousands of times, and the result is a probability distribution of possible outcomes. In this way, Monte Carlo simulation provides a much more comprehensive view of what may happen. It tells you not only what could happen, but how likely it is to happen.
    Monte Carlo simulation provides a number of advantages over deterministic, or “single-point estimate” analysis:
    Probabilistic Results. Results show not only what could happen, but how likely each outcome is.
    Graphical Results. Because of the data a Monte Carlo simulation generates, it’s easy to create graphs of different outcomes and their chances of occurrence. This is important for communicating findings to other stakeholders.
    Sensitivity Analysis. With just a few cases, deterministic analysis makes it difficult to see which variables impact the outcome the most. In Monte Carlo simulation, it’s easy to see which inputs had the biggest effect on bottom-line results.
    Scenario Analysis: In deterministic models, it’s very difficult to model different combinations of values for different inputs to see the effects of truly different scenarios. Using Monte Carlo simulation, analysts can see exactly which inputs had which values together when certain outcomes occurred. This is invaluable for pursuing further analysis.
    Correlation of Inputs. In Monte Carlo simulation, it’s possible to model interdependent relationships between input variables. It’s important for accuracy to represent how, in reality, when some factors goes up, others go up or down accordingly.
    An enhancement to Monte Carlo simulation is the use of Latin Hypercube sampling, which samples more accurately from the entire range of distribution functions.
    Thank you anihita, All the best!
  7. Re: Reserve Estimation-Monte Carlo Simulation
    thank you very much
  1. Monte Carlo Simulation for reserve estimation
    By layibiyi in forum Geology & Exploration
    Last Post: 03-21-2014, 03:45 AM
  2. Reserve estimation methods
    By shawn6820 in forum Reservoir
    Last Post: 11-23-2013, 02:45 AM
  3. reserve estimation of TGRs
    By umair_865311 in forum Reservoir
    Last Post: 02-19-2012, 08:38 PM
  4. reserve estimation
    By mohammed105 in forum Reservoir
    Last Post: 02-17-2012, 05:39 PM
