Hello
I have downloaded etap6 and etap7 full modules and serial activation. I have a desktop intel core i3 windows xp system and I followed the procedure as provided to install but failed to activate the etap please help.
Thanks in advance
Hello
Thanks in advance
please explain step by step your activation procedure in order to help best to solve the problem
1. Downloaded ETAP-7 BUT IT DIDNT CONTAINED PETA7 so I downloaded Peta6 from 4shared.com
2. Disable connection to internet
3. Disable antivirus software on your computer
4. Unzipped and burned on DVD
5. Run Etap-7 installation from DVD.
6. select install + license manager, just follow the instruction.
7. finished installation, and closed the apllication
8. Opened folder LMSETUP\SYSTEM32\DRIVERS on etap DVD
9. copied all files in the LMSETUP\SYSTEM32\DRIVERS ----- to ------ C:\Windows\System32\Drivers\
10. Extracted Peta-6 to C\WINDOWS\ETAP007 then run file " etap6.exe "
9. After finish install --------, then Rebooted computer.
10. Enable again your antivirus
11. Run ETAp 7 application.
BUT IT FAILED to bypass the license manager
Second method
9. Unzip file ETAP_5_Demo_-----.rar
10. Go to your installed Etap folder (C:\etap 700) and locate file 'etapsdb.dll'.
11. Cut it and paste it in a safe folder (or make a copy). You will need it back later.
12. Copy the 'etapsdb.dll' file from ETAP_Demo_-----.rar into the Etap installed folder (C:\etap 700).
13. Run Etap and you will get an error. ETAP will close.
14. Now copy back the original 'etapsdb.dll' back to your Etap 600 folder and replace the existing one.
15. Run again Etap. It should ask for the serial number. Enter serial number given in step 7 above.
THIS METHOD ALSO FAILED
Please help me SIR
Operating system?
Sir i have windows xp 32bit (desktop system)
OK,
read the answer between bracket
(Peta6 is sufficient)
(is not necessary)
(is not necessary)
(good)
(good)
(good)
(good)
(bad)
(bad)
(good, henceforth is no longer necessary)
(good)
(oK)
(UNINSTALL ETAP AND REINSTALL)
(12. TYPE THE REG NUMBER)
where are links for etap
Muhammad Khurram
Do I need to uninstall both ETAP.7 and ETAP.7 LICENSE MANAGER and reinstall.. ? I tried uninstall and reinstall of ETAP.7 only but FAILED
the license manager can not be bypassed................
I think the problem is in my computer. I successfully installed and activated etap on other computer by doing above said procedure.My os preventing the peta6 execution. How can i solve this
