there are many different types of oils with different densities, viscosities etc.,
you may need to specify a composition to calculate the density and the temeperature derivative (expansion coefficient),
you can characterize a mixture then calculate all the required properties with the help of a equation of state, see this thread (where we discuss Prode Properties applications)
'http://www.egpet.net/vb/threads/27092-Excel-library-for-process-calc-s-including-distillation'
differently you may find simplified correlations (density or volume vs. temperature) for generic oils, once you have a generic correlation you should be able to calculate the expansion coefficient, you may find a detailed discussion in "The Properties of Gases and Liquids" by Reid, Prausnitz, Poling
Dear carlo.stenali
Thank you to help me, wishing you continued success
And accept sincerely.
salem001
Salem, You need to specify the oil. Fresh automotive lubricating oil is 0.00070/degree C.
