Results 1 to 10 of 10
Thread: Problem with ChemCAD
    Hi, i'm new here.
    And i have a question regarding the installation of chemcad with the c.rack Chemcad was running on my system but after two months the window "no valid license found" at the beginning popped up. The only magnificent changes i did were the windows updates. I was deactivating my antivirus during installation and placed the c.rack properly. There is a file called "file_id.diz". Do i have to consider this file? I thought maybe someone knows something about this problem.
    Thanks in advance.
    Re: Problem with ChemCAD
    R U using 6.2 version. Looks like it expired on Jan 1 , 2013. It stopped working after that.
    I formatted but it never worked. So go for other version
    Oh this seems to be the Problem. Thank you.
    I used 6.2.0.3348 and after that i tried 6.3.1.4168 but both versions are expired.
    Do you have a suggestion what version could work. Or just keep trying.
    But thank you very much for your help.
    S4Y, Ver 6.1 works but then 6.3 also works but for that you need ur machine connected in Lan If Lan is on 6.3 also works
  7. Re: Problem with ChemCAD
    I had the same problem and had to deactivate my anti virus software while I uninstalled and re-installed ChemCad. Performed the following instructions and ChemCad is working again.
    Instruction:
    1. Install Chemcad-6.3.1-4168.exe
    2. Extract server.zip and run Setup.exe to install Sentinel Server
    3. Extract LM7admin.zip to C:\ directory
    4. In extracted LM7admin directory, run WlmAdmin.exe. Select Edit and Defined Server List option. Enter your local machine IP address and click OK to add server
    5. Click on new server address in tree menu and right click to select Add feature|From a File|Add feature from file|To Server and Its File. When prompted browse and select "lservrc" file in ----- folder
    6. When you expand your defined server should see features available
    7. Open Chemcad, no license screen appears, click setup and then select Add/Remove Server option
    8. If server not in list, select "license server" under the Select server type drop down and then enter IP address used in Step 4
    9. Chemcad is -----ed and run with all features!
    this version is very old. the actuel version is 6.5.2
    Hi, i can't find such server.zip or LM7admin.zip. It's even not in the installed folder of chemcad. The c.rack in my version is just a cc6.exe file nothing else. Are those zip files coming with your main setup file of chemcad.
    When i start ChemCAD, i turn on the LAN but still doesnt work.
    Thank you very much for your help really appreciate that.
    Oct 2012
    Jakarta, Surabaya, Semarang, Palembang, Lampung, Malang, Indonesia
    Blog Entries
    1
    hi,,
    I have CHEMCAD 6.3.1.4168, but I did not find the file server.zip and LM7 admin.zip,, there is only CHEMCAD 6.3.1.4168.exe and CC6.exe course, get you to send the file to me, please? because I really need it for my job,,
    Thank you very much,,
    Hi! jxd3261, I believe I have the 6.3.1-4168 version, but missing certain files to enable do a proper installation. Please can you send me the link or probably your rar file for the 6.3.1-4168? My email is desde_monaaa at yahoo dot com. Thanks!
    If you want the c.racked version to run (auto detect the license), just change the OS date to a year like 2012.
  1. Replies: 9
    Last Post: 05-24-2011, 08:08 AM
