Thread: API 5L Grade B VS ASTM A106
  1. API 5L Grade B VS ASTM A106
    Can anybody help me to find some standard were is writting that API 5L Grade B may use instead of ASTM A106.
  3. Re: API 5L Grade B VS ASTM A106
    ASTM New Documents ....
    Document Number Date Title
  5. Re: API 5L Grade B VS ASTM A106
  1. equivalent Pipe material for Astm A106 Gr.C
    By getarulselvan@gmail.com in forum Oil And Gas Process
    Last Post: 07-30-2014, 07:52 PM
  2. Astm a106 - 2011 edition required
    By muzammil in forum Materials Science &Corrosion
    Last Post: 02-13-2014, 06:37 AM
  3. SA 106 Gr B and ASTM A106 Gr B
    By hakr5 in forum Mechanical Engineering
    Last Post: 07-09-2013, 12:46 AM
  4. Astm a53/ astm a106
    By umashankarsingh in forum Materials Science &Corrosion
    Last Post: 02-28-2011, 02:20 PM
