Results 1 to 11 of 11
Thread: Astm g48
  1. Astm g48
    Any friend could share ASTM G48
    thank you in advance
    Re: Astm g48
    Hi
    here you are
    enjoy it.
    Attached Files Attached Files
  5. Re: Astm g48
    thank you very much
  6. Re: Astm g48
    Quote Originally Posted by siamak View Post
    Hi
    here you are
    enjoy it.
    thank you very much
  7. Re: Astm g48
    Thank you very much
  9. Re: Astm g48
    ASTM New Documents ....
    Document Number Date Title
  10. Re: Astm g48
    hye..u have latest version of g48?
    Re: Astm g48
    Hi
    here you are
    enjoy it.
    thank you
    Re: Astm g48
    Please againg upload ASTM G48 (A) method
  13. Re: Astm g48
    Dear friends'
    I need "ASTM E8/E8M,Standard test methods for tension testing of metallic materials,2011" and "API RP 2EQ"
    Could you please send me these standards.
    My ID is: Ro.Rezaei@gmail.com
    Best Regards
  14. Re: Astm g48
    Dear friends'
    Best Regards
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM A262, ASTM G108 ASTM A923 are required
    By mohammed21 in forum Mechanical Engineering
    Last Post: 12-13-2014, 07:21 AM
  4. Replies: 2
    Last Post: 04-21-2013, 10:30 AM
  5. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
