Thread: help me. how to draw some contour on this map
  1. Post help me. how to draw some contour on this map
    Hello. I am studying in a geo structural class. I need to draw some contours. It's very simple and easy but i don't know how to do it.
    I have here 3 cross sections aa', bb' and cc' that i already projected on the base map. So i have values along the section lines but i dont know how to connect them all.
    Please anyone can help me to draw some line on this map? You can take a screenshot and draw some lines using Ms. Paints in windows. Thanks and i really appreciate for this.
    Jun 2007
    Cairo, Egypt, Egypt
    Re: help me. how to draw some contour on this map
    i have seen your sections, you have one fault and one horizon (one surface) here you are some tips :
    1- first draw the fault projection , connect the two upthrown sides together with one line , and the two down thrown sides with another line ... extend both lines if you want till the end of map ... (points of up-thrown & down-thrown are red on your sections)
    2- now you have two parts of the map .. northern part which is up-thrown side of the map and southern part which is down-thrown side.
    3- contour each side of the map (up and down) separately by connecting the same depth values together.
    4- extrapolate lines of contours in all sides.
    5- make sure that every contour line is passing through same elevation values.
    6- make sure there is no crossed lines in your map.
    7- make sure that all points between any 2 contour lines have elevation values between the elevation values of both lines.
    good luck
  5. Re: help me. how to draw some contour on this map
    [link Point to another website Only the registered members can access] phongnguyen0581 can u upload some more examples like these plss........
  6. Re: help me. how to draw some contour on this map
  1. PHAST-Risk contour
    By kalamj in forum Safety And Environment
    Last Post: 05-17-2014, 05:17 PM
  2. help me to draw some contour line on map!
    By phongnguyen0581 in forum Civil & Structural Engineering
    Last Post: 01-26-2013, 11:07 PM
  3. Looking for smart draw or like
    By sethubalajirao in forum Computer & Internet
    Last Post: 11-04-2009, 04:51 PM
