Dear Members,
I want to build a Petrel model using 2D map. I have a structure map with fault traces. How I build model in Petrel with taking these fault lines and surface? Please give details procedure.
Dear Members,
you can do that very easy and quick :
1- use your horizons and faults to build a structure framework
2- adjust the framework as you wish qc your fault and horizon interpretation from the framework until you have final picture of the structure model
3-use the process named structure model from structure framework , you can find it in the processes tab .
4-do your pillar geometry and make horizon process and you will have your structure model
structure framework serve as your carpet to the structure model .
the idea behind using structure framework is that it do a lot of things easily for you while you are interpreting or after interpretation and it cancels a lot of the hard things in the structure model creation by old ways .
I have a 2D map where where 2D contour lines and fault traces are there. I want to build the model in Petrel using this map. First I digitize the map, then how I build model in Petrel?
