Thread: Need ASTM D2013. Help me,please
  1. Need ASTM D2013. Help me,please
    Dear Alls
    Any one have ASTM D2013 / D2013M - 12 Standard Practice for Preparing Coal Samples for Analysis. Share to me, please.
    Thanks you so much.
    Waiting for yous
  3. Re: Need ASTM D2013. Help me,please
    Hope this will help.
  6. Re: Need ASTM D2013. Help me,please
    ASTM New Documents ....
    Document Number Date Title
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM A262, ASTM G108 ASTM A923 are required
    By mohammed21 in forum Mechanical Engineering
    Last Post: 12-13-2014, 07:21 AM
  4. Replies: 2
    Last Post: 04-21-2013, 10:30 AM
  5. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
