Results 1 to 10 of 10
Thread: making schedule file using Excel
  1. making schedule file using Excel
    Hi guys
    I am going to make schedule file to use in eclipse using Excel. The field has high number of well and long history. Can anybody help me how to do this job using excel? Which data I will need? How to make the right format etc.?
    Thanks for your help in advance.
    Re: making schedule file using Excel
    Its simple, just put one item in one cell.. when you copied from excel to notepad data will be pasted as tab delimited.
    Bilal Amjad
  5. Re: making schedule file using Excel
    Thanks for your reply Bilal. Do you have any template for this job? I don't get your point about the file format.
  6. Re: making schedule file using Excel
    Hello ,
    I've created an Excel code for this.
    Send me your email via PM.
    hi
    sorry for late response, i though it is better late than never :-)
    i attach spreadsheet that can be adapted for your needs.
    basically it takes production rates and pressures from respective pages. here is for gas but very easy to change to oil.
    i usually have all wells from the start but if rates are zero it will give shut or stop (see N2). this simplifies job as i don't have to add wells later but makes file big. just copy rows 18 to 34 and paste to row 35 it should have next month (look at formulas). once copied to text file select spaces and ctr+h replace/delete them or eclipse doesn't like it. summs of respective columns can help to verify inputs...
    if anyone can share theirs templates that would be appreciated.
    Attached Files Attached Files
  9. Re: making schedule file using Excel
    Dear All,
    Here is another one.
    Thanks!
    Dec 2008
    Venezuela
    Thanks! the excel files seem to be very useful.
  12. Re: making schedule file using Excel
    Dear Halim,
    I did try yr Excel script, but it seem to be not work. Nothing happen when I click "Format 2 Sched" bottom after filling my data into Production and Injection tabs.
    Did you test yr script with different data, Mr Halim?
    For any matter, I can be reach at sang3011@gmail.com
    regards,
  13. Re: making schedule file using Excel
    Quote Originally Posted by sang_3011 View Post
    Dear Halim,
    regards,
    Hello Sang,
    Yes, I tested the script with real data for many projects and it worked fine.
  1. Piping table, excel file, very good
    By jester-s in forum Engineering Spreadsheets & Presentations
    Last Post: 09-02-2015, 06:58 PM
  2. Electrical cable voltage drop calculation excel file attached
    By sandeep_walunj@yahoo.com in forum Instrumentation & Control
    Last Post: 11-20-2013, 02:05 PM
  3. Who can share pipe insulation sizing and design software or excel file?
    By williamsking in forum Pipeline And Fluid Flow
    Last Post: 07-14-2013, 08:35 AM
  4. Process Safety KPIs (Excel file with formulae)
    By muhammad usman in forum Petrochemical
    Last Post: 06-20-2012, 11:07 PM
