can anyone explain to me about this topic for URL,LRL,URV,LRV and cripped mode and selection of range.
Dear Amirul,
These are basic Instrumentation Terms and the main source of such teminology is the Standard ISA S 5.11: Process Instrumentation Terminology.
Sourcing from above your mentioned terms mean as follows:
lrl= lower range-limit: The lowest value of the measured variable that a device can be adjusted to measure.
url= upper range-limit : The highest value of the measured variable that a device can be adjusted to measure.
lrv= lower range-value: The lowest value of the measured variable that a device is adjusted to measure.
urv= upper range-value: The highest value of the measured variable that a device is adjusted to measure.
Sajid Ali Khan
