Results 1 to 10 of 10
Thread: Need help in KAPPA plot interpretation
  1. Need help in KAPPA plot interpretation
    Hey guys,
    Struggling with these two KAPPA plots interpretations .
    In semi-log plot where IARF starts from ? Where PSS starts from? What does "hump " in the middle mean?
    I think that's not wellbore storage as it starts at the top of the plot.
    Thanks.
    Re: Need help in KAPPA plot interpretation
    Looks like tight reservoir with at least two no flow boundaries
    Regi
  5. Re: Need help in KAPPA plot interpretation
    Quote Originally Posted by REGI_MAX View Post
    Regi
    Where IARF starts from?
    Dec 2007
    Novi Sad, Serbia
    ÑÏ: Re: Need help in KAPPA plot interpretation
    can you provide diagnostic plot ?
  7. Re: Need help in KAPPA plot interpretation
    You meant these?
    Dec 2007
    Novi Sad, Serbia
    Yes, that plot . I believe you are dealing with two sealing faults, but you should check geology data first. Try to check the slope of the raising at the end, if the slope is ½ you probably have a channel (Two parallel faults), but if it is less try to use Intersecting faults with angle. Did you had any stimulation job?
  10. Re: Need help in KAPPA plot interpretation
    this well has low permeability and produce from small reservoir or bounded structure (late time response of dignostic plot is unit slope indicating depletion!)
  11. Re: ÑÏ: Re: Need help in KAPPA plot interpretation
    Yes, you are right, Ivan. The reservoir has parallel faults system. I am student doing Petroleum Engineering, so I am novice in reservoir simulation.
    Thank you for you reply.
  12. Re: ÑÏ: Re: Need help in KAPPA plot interpretation
    Quote Originally Posted by ivan_aljeburi View Post
    Thanks for your reply. Do you have idea how to draw the following graph in KAPPA.I have attached it.
    Dec 2007
    Novi Sad, Serbia
    ÑÏ: Need help in KAPPA plot interpretation
    If you have several drawdown/build up-s is one measurement you can compare them.. here how you can do it:
    Go to Extraxt dP
    then Select group and click on List
    then select what do you want to compare then click OK
    Or you can compare two different wells :
    Open Ecrine project you want to compare
    Well 1, Well2….
    Then go to Output menu and select compare files
    Best regards
  1. Well testing_Horner Plot vs Derivatives?
    By izimrat in forum Reservoir
    Last Post: 05-18-2013, 02:54 AM
  2. PPD plot in pansystem
    By anby13 in forum Reservoir
    Last Post: 08-23-2012, 04:04 AM
  3. Diagnostic plot of a Gas well Build Up
    By ramprasad153 in forum Reservoir
    Last Post: 03-24-2012, 08:38 PM
  4. Campbell Plot
    By dipak_m in forum Reservoir
    Last Post: 09-28-2010, 07:07 PM
