Results 1 to 6 of 6
Thread: Pvt
  1. Pvt
    hi evreybody,
    I have a problem regarding the PVT, in fact a PVT sample was taken in the gas zone or in the tranzition zone (oil-gas) showing that my reservoir is a gas condensate reservoir, then we realized that this is not true and my real reservoir fluid is oil, can I determine the real PVT data for my oil phase using the available data?
    thanks in advance
  3. Re: Pvt
    nothing to say?
  5. Re: Pvt
    Hello Ganshen,
    two questions, where did you take the sample, at the separator or downhole?, and what makes you think that is a oil field?
    regards
    Resident_evil
  6. Re: Pvt
    it's a separator sample, in reality we realized that an oil rim exist
  7. Re: Pvt
    Comments..
    Options:
    1.- It is best to take another sample from oil zone.
    Does it matter if it is not from the beginning of the production? [/B]
    Depends on bubble point. It is best if pressure is above bubble point.
    2.- take samples (gas + oil) at surface and recombine (from oil interval)
    Doesn’t, because separator conditions are below bubble point.
    3.- If not possible, recombine gas and oil from transition zone (last option).
  9. Re: Pvt
