Results 1 to 8 of 8
Thread: gas pipeline hydraullics
  1. Exclamation gas pipeline hydraullics
    Dear Friends
    Kindly help with the most appropriate equation for calculating the friction factor in a a gas pipeline under turbulent condition
  3. Re: gas pipeline hydraullics
    Colebrook-White equation will work for you case (Nre>4000)
  5. Re: gas pipeline hydraullics
    Mr Fucheng
    if i am correct this is the equation you are talking about:F^(-1/2)=-2LN((e/3.7D)+2.51/(Re(F^1/2))
    Please Kindly explain how to go about it since we have two F''
  6. Re: gas pipeline hydraullics
    If you go to Wikipedia "Darcy Friction Factor Formulae" you will find an description of the Goudar-Sonnad equation which was published in Hydrocarbon Processing in August 2008. This has an explicit solution so an iterative approach is not necessary. Goudar and Sonnad published an earlier paper in the April 2007 issue which covered similar material. Both worth reading if you can find them. The answer you want is at Wikipedia.
    Cool Re: gas pipeline hydraullics
    According to the definition Reynolds number can be calculated using equation:
    Re=ωdρ/μ=ωd/ν;
    Laminar flow - Re<2300;
    Transition zone (or crossover) - 2300<Re<10000;
    Turbulent flow - Re>10000.
    For a laminar flow (Re<2300) the equation for calculation of Friction Factor ( λ ) is as follows:
    λ=64/Re;
    For a laminar flow there’s no dependence of λ from roughness of pipe walls.
    For a turbulent flow (Re>2300) the equation for calculation of λ is as follows:
    λ=0,316/Re0.25 - this equation can be applied for hydraulically smooth pipes and for the Reynolds number not exceeds Re>100000;
    For rough pipes λ can be calculated according the equation:
    1/(√λ)=-2lg⌊ε/3.7+(16.81/Re)0.9
    in this equation is:
    ε - relative roughness, that can be calculated based on the equation:
    ε=e/de
    where is:
    e (in mm) - intermediate size of pipe’s hills or hillocks (pipe roughness) can be found in the appropriate theoretical tables;
    de (in mm) - equivalent diameter of a pipe.
    I hope this info will be helpfull
  9. Re: gas pipeline hydraullics
    Thanks Grimm.. Please can you kindly give me a reference
    This info was taken from the Russian book "Pavlov K.F., Romankov P.G., Noskov A.A. "Examples and tasks for the course of processes and apparatuses of chemical technology", pages 21-22, equations 1.38, 1.40, 1.41, 1.42.
  11. Re: gas pipeline hydraullics
    Thanks Mr Grimm.. Please can you upload the book... or send a link where i can download it from.
  1. Replies: 6
    Last Post: 04-15-2016, 09:01 AM
  2. Replies: 0
    Last Post: 05-21-2014, 03:06 PM
  3. Can anyone put light on pipeline repair of inflow petroleum pipeline ?
    By chetan_ladia in forum Pipeline And Fluid Flow
    Last Post: 07-13-2013, 08:33 AM
  4. first pipeline
    By dckchoudary in forum Pipeline And Fluid Flow
    Last Post: 06-30-2009, 11:30 AM
  5. Pipeline Manifold and Pipeline for Avtur
    By Tengku_Syahdilan in forum Pipeline And Fluid Flow
    Last Post: 12-22-2008, 11:32 AM
