Thread: Model a deaerator in Apsen Plus
  1. Model a deaerator in Apsen Plus
    Can anyone give my guidance on how to model a deaerator in Apsen Plus version 7.3?
    Thank you in advance.
    Re: Model a deaerator in Apsen Plus
    Deareator function is to strip oxygen off the boiler feed water. The Deareator has Deareator section ( can be tray or spray type refer HEI standard). So you need water and oxygen as components. The deareation section can be modelled by radfrac with 4 actual trays of M eff of 50%. The feeds would be fresh soft water make-up and condensate return. Ou would be vent and water out. This goes to say vessel. The vessel in is team for stripping and out would be the steam component full and water from deareator section. The idea is have sufficient vent flow to get desired do level in boiler feed water
  5. Re: Model a deaerator in Apsen Plus
    thank you very much. Regards
  1. Deaerator Design and HEI Standard
    By padua in forum Oil And Gas Process
    Last Post: 09-20-2017, 11:50 PM
  2. Deaerator design
    By dms92 in forum Mechanical Engineering
    Last Post: 04-06-2014, 04:14 PM
  3. Deaerator Design
    By mo736 in forum Mechanical Engineering
    Last Post: 02-16-2014, 10:51 PM
  4. About deaerator book
    By huifa in forum Mechanical Engineering
    Last Post: 08-17-2010, 04:36 PM
