Thread: Pressure Enthalpy diagram
    Can someone please help with pressure enthalpy software for various components?
    Re: Pressure Enthalpy diagram
    you should define a EOS model to calculate the enthalpy departure from ideal gas values calculated with some correlation, there are examples with VBA of SRK or PR which you may adapt.
    As alternative you may consider to link a simulator or a process library which does all the calc's, then you export to Excel or Matlab.
    I have tested Prode Properties (see 'www.prode.com') which integrates directly with Excel and does all you need.
    do you wish to calculate P-H graphs for pure fluids or mixtures?
    For mixtures there are examples discussed here
    'http://www.egpet.net/vb/threads/27092-Excel-library-for-process-calc-s-including-distillation?p=224959#post224959'
  6. Re: Pressure Enthalpy diagram
    Quote Originally Posted by MartinST View Post
    I would recommend you to use EES (Engineering Equation Solver) software.
  1. Enthalpy balance modelling in PROSPER
    By UsmanHWU in forum Reservoir
    Last Post: 07-12-2013, 12:48 PM
  2. Article: Pressure Enthalpy diagram
    By MartinST in forum Home Articles
    Last Post: 03-26-2013, 03:13 AM
  3. How to convert these enthalpy units?
    By drag0n in forum Oil And Gas Process
    Last Post: 12-20-2010, 09:40 AM
  4. Replies: 2
    Last Post: 10-01-2010, 03:56 AM
  5. Wanted: Pressure-enthalpy diagram ethylene (Mollier)
    By goosje in forum Petrochemical
    Last Post: 09-13-2009, 06:02 AM
