Thread: glycol-water distillation
    A feed mix conatining 90% meg and 8-10 % water is to be distilled batchwise. Can anyone guide on foaming issues associated with this feed?
  3. Re: glycol-water distillation
    Foaming issues will depend on the cleanliness of the feed. Hydrocarbons, organic compounds, additives and particulates will all act to promote/stabilize foam. The best solution is to make sure it is clean, this means proper filtration, best is to have a particulate filter, activated charcoal filter and an afterfilter for removal of charcoal fines. If a significant amount of liquid HC is expected, a liquid/liquid separator is required.
    ColinR33, Thanks. By the way any azeotrope between meg and deg ( mono and di ethylene glycol)?
  6. Re: glycol-water distillation
    Not that I am aware of, MEG Globals website has good info.
  1. Replies: 1
    Last Post: 10-31-2013, 10:56 AM
  2. Replies: 3
    Last Post: 07-09-2010, 03:42 PM
  3. Replies: 0
    Last Post: 06-18-2010, 10:36 PM
