Results 1 to 8 of 8
Thread: My 'Most Wanted' Standards List
    Question My 'Most Wanted' Standards List
    Hi folks,
    I didn't wanted to bother you by creating a lot of requests, so I thought to create my own 'Wish List' of standards.
    I was looking for quite a while for these standards and could not find them, so if anyone could help me or at least check for some if available in their 'Database', would be greatly appreciated.
    Thank you very much in advance!
    He I go...
    1. prEN 12259-9-2004 Fixed firefighting systems. Components for sprinkler and water spray systems. Part 9. Deluge alarm valve assemblies
    2. ISO 16312-1:2010 Guidance for assessing the validity of physical fire models for obtaining fire effluent toxicity data for fire hazard and risk assessment
    3. ISO/TR 16312-2:2007 Guidance for assessing the validity of physical fire models for obtaining fire effluent toxicity data for fire hazard and risk assessment Part 2: Evaluation of individual fire models
    4. ISO 16735:2006 Fire safety engineering. Requirements governing algebraic equations. Smoke layers
    5. ISO 12239:2010 Smoke alarms using scattered light, transmitted light or ionization
    6. ISO 6182-12:2010 Fire protection. Automatic sprinkler systems. Part 12: Requirements and test methods for grooved-end components for steel pipe systems
    7. ISO 6826:1997 Reciprocating internal combustion engines. Fire protection
    8. ISO 21542:2011 Building construction. Accessibility and usability of the built environment
    9. ISO/TS 21220:2009 Particulate air filters for general ventilation. Determination of filtration performance
    10. EN ISO 13792:2012 Thermal performance of buildings. Calculation of internal temperatures of a room in summer without mechanical cooling. Simplified methods
    11. EN 14239:2004 Ventilation for buildings. Ductwork. Measurement of ductwork surface area
    12. EN 822:1995 Thermal insulating products for building applications. Determination of length and width
    13. EN 823:1995 Thermal insulating products for building applications. Determination of thickness
    14. EN 12939:2001 Thermal performance of building materials and products. Determination of thermal resistance by means of guarded hot plate and heat flow meter methods. Thick products of high and medium thermal resistance
    15. EN 16009:2011 Flameless explosion venting devices
    16. EN 14466:2005+A1:2008 Fire-fighting pumps. Portable pumps. Safety and performance requirements, tests
    17. CEN/TS 15117:2005 Guidance on direct and extended application
    18. CEN/TS 15447:2006 Mounting and fixing in reaction to fire tests under the Construction Products Directive
    19. EN 14135:2004 Coverings. Determination of fire protection ability
    20. EN 14390:2007 Fire test. Large-scale room reference test for surface products
    21. EN 13141-1:2004 Ventilation for buildings. Performance testing of components/products for residential ventilation. Externally and internally mounted air transfer devices
    22. EN 13141-2:2010 Ventilation for buildings. Performance testing of components/products for residential ventilation. Exhaust and supply air terminal devices
    23. EN 13141-3:2004 Ventilation for buildings. Performance testing of components/products for residential ventilation. Range hoods for residential use
    24. EN 13141-4:2011 Ventilation for buildings. Performance testing of components/products for residential ventilation. Fans used in residential ventilation systems
    25. EN 13141-5:2004 Ventilation for buildings. Performance testing of components/products for residential ventilation. Cowls and roof outlet terminal devices
    26. EN 13141-6:2004 Ventilation for buildings. Performance testing of components/products for residential ventilation. Exhaust ventilation system packages used in a single dwelling
    27. EN 13141-7:2010 Ventilation for buildings. Performance testing of components/products for residential ventilation. Performance testing of a mechanical supply and exhaust ventilation units (including heat recovery) for mechanical ventilation systems intended for single family dwellings
    28. EN 13141-8:2006 Ventilation for buildings. Performance testing of components/products for residential ventilation. Performance testing of un-ducted mechanical supply and exhaust ventilation units (including heat recovery) for mechanical ventilation systems intended for a single room
    29. EN 13141-9:2008 Ventilation for buildings. Performance testing of components/products for residential ventilation. Externally mounted humidity controlled air transfer device
    30. EN 13141-10:2008 Ventilation for buildings. Performance testing of components/products for residential ventilation. Humidity controlled extract air terminal device
    31. EN 14134:2004 Ventilation for buildings. Performance testing and installation checks of residential ventilation systems
    32. EN 15643-1:2010 Sustainability of construction works. Sustainability assessment of buildings. General framework
    33. EN 15643-2:2011 Sustainability of construction works. Assessment of buildings. Framework for the assessment of environmental performance
    34. EN 15643-3:2012 Sustainability of construction works. Assessment of buildings. Framework for the assessment of social performance
    35. EN 15643-4:2012 Sustainability of construction works. Assessment of buildings. Framework for the assessment of economic performance
    36. EN 13203-3:2010 Solar supported gas-fired domestic appliances producing hot water. Appliances not exceeding 70 kW heat input and 500 litres water storage capacity. Assessment of energy consumption
    37. prEN 13203-4-2010 Gas fired domestic appliances producing hot water. Part 4. Assessment of energy consumption of gas fired appliances combined heat and power (micro CHP) producing hot water and electricity not exceeding 70 kW heat input, not exceeding 50 kWe electrical output and 500 l water storage capacity
    38. EN 50440:2006 Efficiency Of Domestic Electrical Storage Water Heaters
    39. EN 14459:2007 Control functions in electronic systems for gas burners and gas burning appliances. Methods for classification and assessment
    40. CEN/TR 1749:2009 European scheme for the classification of gas appliances according to the method of evacuation of the combustion products (types)
    41. EN 14241-1:2005 Chimneys. Elastomeric seals and elastomeric sealants. Material requirements and test methods. Seals in flue liners
    42. EN 304:1992 Heating boilers. Test code for heating boilers for atomizing oil burners
    43. EN 308:1997 Heat exchangers. Test procedures for establishing the performance of air to air and flue gases heat recovery devices
    44. EN 14394:2005+A1:2008 Heating boilers. Heating boilers with forced draught Burners. Nominal heat output not exceeding 10 MW and maximum operating temperature of 110°C
    45. EN 12977-1:2012 Thermal solar systems and components. Custom built systems. General requirements for solar water heaters and combisystems
    46. EN 12977-2:2012 Thermal solar systems and components. Custom built systems. Test methods for solar water heaters and combisystems
    47. EN 12977-3:2012 Thermal solar systems and components. Custom built systems. Performance test methods for solar water heater stores
    48. EN 12977-4:2012 Thermal solar systems and components. Custom built systems. Performance test methods for solar combistores
    49. EN 12977-5:2012 Thermal solar systems and components. Custom built systems. Performance test methods for control equipment
    50. ISO 9459-2-1995 Solar heating - Domestic water heating systems - Outdoor test methods for system performance characterization
    51. EN 14588:2010 Solid biofuels. Terminology, definitions and descriptions
    52. EN 14961-1:2010 Solid biofuels. Fuel specifications and classes. General requirements
    53. EN 14961-2:2011 Solid biofuels. Fuel specifications and classes. Wood pellets for non-industrial use
    54. EN 14961-3:2011 Solid biofuels. Fuel specifications and classes. Wood briquettes for non-industrial use
    55. EN 14961-4:2011 Solid biofuels. Fuel specifications and classes. Wood chips for non-industrial use
    56. EN 14961-5:2011 Solid biofuels. Fuel specifications and classes. Firewood for non-industrial use
    57. EN 14961-6:2012 Solid biofuels. Fuel specifications and classes. Non-woody pellets for non-industrial use
    58. EN ISO 13791:2012 Thermal performance of buildings. Calculation of internal temperatures of a room in summer without mechanical cooling. General criteria and validation procedures
    59. ISO 6944-2:2009 Fire containment. Elements of building construction. Part 2. Kitchen extract ducts
    60. ISO 5151:2010 Non-ducted air conditioners and heat pumps. Testing and rating for performance
    61. ISO 1996-1-2003 Acoustics - Description, measurement and assessment of environmental noise - Basic quantities and assessment procedures
    62. ISO 1996-2-2007 Acoustics - Description, measurement and assessment of environmental noise - Determination of environmental noise levels
    63. EN 13618:2011 Flexible hose assemblies in drinking water installations. Functional requirements and test methods
    64. EN 806-4:2010 Specifications for installations inside buildings conveying water for human consumption. Installation
    65. EN 806-5:2012 Specifications for installations inside buildings conveying water for human consumption. Operation and maintenance
    66. EN 1488:2000 Building valves. Expansion groups. Tests and requirements
    67. EN 1490:2000 Building valves. Combined temperature and pressure relief valves. Tests and requirements
    68. EN 1491:2000 Building valves. Expansion valves. Tests and requirements
    69. EN 14506:2005 Devices to prevent pollution by backflow of potable water. Automatic diverter. Family H, type C
    70. EN ISO 17672:2010 Brazing. Filler metals
    71. EN ISO 10893-1:2011 Non-destructive testing of steel tubes. Automated electromagnetic testing of seamless and welded (except submerged arc-welded) steel tubes for the verification of hydraulic leaktightness
    72. EN ISO 10893-2:2011 Non-destructive testing of steel tubes. Automated eddy current testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of imperfections
    73. EN ISO 10893-3:2011 Non-destructive testing of steel tubes. Automated full peripheral flux leakage testing of seamless and welded (except submerged arc-welded) ferromagnetic steel tubes for the detection of longitudinal and/or transverse imperfections
    74. ISO 10893-4:2011 Non-destructive testing of steel tubes. Liquid penetrant inspection of seamless and welded steel tubes for the detection of surface imperfections
    75. EN ISO 10893-5:2011 Non-destructive testing of steel tubes. Magnetic particle inspection of seamless and welded ferromagnetic steel tubes for the detection of surface imperfections
    76. EN ISO 10893-6:2011 Non-destructive testing of steel tubes. Radiographic testing of the weld seam of welded steel tubes for the detection of imperfections
    77. EN ISO 10893-7:2011 Non-destructive testing of steel tubes. Digital radiographic testing of the weld seam of welded steel tubes for the detection of imperfections
    78. EN ISO 10893-8:2011 Non-destructive testing of steel tubes. Automated ultrasonic testing of seamless and welded steel tubes for the detection of laminar imperfections
    79. EN ISO 10893-9:2011 Non-destructive testing of steel tubes. Automated ultrasonic testing for the detection of laminar imperfections in strip/plate used for the manufacture of welded steel tubes
    80. EN ISO 10893-10:2011 Non-destructive testing of steel tubes. Automated full peripheral ultrasonic testing of seamless and welded (except submerged arc-welded) steel tubes for the detection of longitudinal and/or transverse imperfections
    81. EN ISO 10893-11:2011 Non-destructive testing of steel tubes. Automated ultrasonic testing of the weld seam of welded steel tubes for the detection of longitudinal and/or transverse imperfections
    82. EN ISO 10893-12:2011 Non-destructive testing of steel tubes. Automated full peripheral ultrasonic thickness testing of seamless and welded (except submerged arc-welded) steel tubes
    83. EN 15502-1:2012 Gas-fired heating boilers. General requirements and tests
    84. prEN 15502-2-1-2010 Gas-fired heating boilers. Part 2-1. Specific standard for type C appliances and type B2, B3 and B5 appliances of a nominal heat input not exceeding 1000 kW
    85. EN 88-1:2011 Pressure regulators and associated safety devices for gas appliances. Pressure regulators for inlet pressures up to and including 50 kPa
    86. EN 88-2:2007 Pressure regulators and associated safety devices for gas appliances. Pressure regulators for inlet pressures above 500 mbar up to and including 5 bar
    87. EN 14597:2012 Temperature control devices and temperature limiters for heat generating systems
    88. ISO 16730:2008 Fire safety engineering -- Assessment, verification and validation of calculation methods
    89. ISO 16734:2006 Fire safety engineering -- Requirements governing algebraic equations -- Fire plumes
    90. ISO 16735:2006 Fire safety engineering -- Requirements governing algebraic equations -- Smoke layers
    91. ISO 16736:2006 Fire safety engineering -- Requirements governing algebraic equations -- Ceiling jet flows
    92. ISO 16737:2006 Fire safety engineering -- Requirements governing algebraic equations -- Vent flows
    93. ISO/TR 16738:2009 Fire-safety engineering -- Technical information on methods for evaluating behaviour and movement of people
    94. EN 15331:2011 Criteria for design, management and control of maintenance services for buildings
    95. EN 13269:2006 Maintenance. Guideline on preparation of maintenance contracts
    143. EN 14055:2010 WC and urinal flushing cisterns (acquired Thanks to Abo Khaled - see post #2)
    145. EN 13443-2:2005+A1:2007 Water conditioning equipment inside buildings. Mechanical filters. Particle rating 1 μm to less than 80 μm. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    146. EN 14743:2005+A1:2007 Water conditioning equipment inside buildings. Softeners. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    147. EN 14812:2005+A1:2007 Water conditioning equipment inside buildings. Chemical dosing systems. Pre-set dosing systems. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    148. EN 14897:2006+A1:2007 Water conditioning equipment inside buildings. Devices using mercury low-pressure ultraviolet radiators. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    149. EN 14898:2006+A1:2007 Water conditioning equipment inside buildings. Active media filters. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    150. EN 15219:2006+A1:2007 Water conditioning equipment inside buildings. Nitrate removal devices. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    151. EN 14095:2003 Water conditioning equipment inside buildings. Electrolytic treatment with aluminium anodes. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    152. EN 14652:2005+A1:2007 Water conditioning equipment inside buildings. Membrane separation devices. Requirements for performance, safety and testing (acquired Thanks to Abo Khaled - see post #2)
    Best Regards,
    georgecis
    Last edited by georgecis; 09-02-2012 at 04:01 PM. Reason: Shortened the list a bit, maybe will get better feed-back... :)
  3. Re: My 'Most Wanted' Standards List
    Please see this ink for part of your list for water treatment
    Greetings
    Abo Khaled1
    Attached Files Attached Files
    Thank you very much Abo!
    Greatly appreciated, I will gladly help too anytime if I can.
    georgecis
  6. Re: My 'Most Wanted' Standards List
    The link doesn't exist. Plz re-upload.
    Thanks,
    A Aslam.
    Quote Originally Posted by Abo Khaled View Post
    Greetings
    Abo Khaled1
    Quote Originally Posted by aabdulaslam@gmail.com View Post
    Thanks,
    A Aslam.
    Hi,
    Don't click directly on the link in the post, Copy/Paste the whole line (https://rapidshare.com/files/159091274/Water Treatment Standards.rar) into your browser.
    Hope it helps.
    georgecis
  9. Re: My 'Most Wanted' Standards List
    Thanks a lot.
    A Aslam.
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Thks for the share
    Nov 2010
    Sao Paulo SP Brazil
    Rapidshare is no longer working (FBI closed it). Do you have yours stadards in any other link? Best regards
  1. IEC Check List
    By sallu1 in forum Safety And Environment
    Last Post: 08-06-2014, 10:53 AM
  2. List of Automation Standards from OGP
    By mealyyu in forum Instrumentation & Control
    Last Post: 03-22-2014, 09:52 PM
  3. Standards List (DCS/ESD)
    By klepto in forum Oil And Gas Process
    Last Post: 01-13-2012, 10:10 PM
  4. list of standards
    By ali in forum General Engineering
    Last Post: 07-20-2011, 10:11 AM
  5. List of EPC COmpanies
    By bctian in forum Oil And Gas Process
    Last Post: 11-13-2009, 11:35 PM
