Dear all,
could you help me to find the following standard? ASTM A751
If anybody has, please share
Dear all,
ASTM A751 :[link Point to another website Only the registered members can access]
If you download and find it useful, just click on Thanks button !
Visit and become a member of
Welding Engineering & Inspection group
Here:[link Point to another website Only the registered members can access]
I checked again , link works fine .
Hi netspyking,
If you have checked again and the link is still available.
So, I do not know where the problem is, because I always have the same message.
"The file link that you requested is not valid"
By the way, can you upload it on another site.
Thanks in advance.
Hi,
The link worked for me, thank you netspyking. Hope you don't mind, I've uploaded it to MediaFire for those who have problems with 4Shared.[link Point to another website Only the registered members can access]
georgecis
Thanks for your help
the file had been removed?
could anyone help pls?
required : ASTM A751 - 11
thank you
if you need this document
please contact to :
internationalstandard2012(at sign)gmail(dot)com
ASTM New Documents ....
Document Number Date Title
