Thread: Compress_Build_6258
    Compress_Build_6258
    I Was able to run install emulator in LND EMULATOR UTILITY but after that when i tried to run Compress an error says that
    "Compress has found a security key emulator on your computer.
    Compress will not run on computers with security key emulator program has been installed.
    closing and uninstalling emulator program is required for compress to run.
    Compress will now shut down"
    Please Help
  3. Re: Compress_Build_6258
    use administrator user for install emulator again
    same issue i have try
    May 2009
    Jubail Saudi Arabia
    Quote Originally Posted by sameerahmed View Post
    Sameer,
    I have encountered the same problem but still i managed to install that software by uninstalling every file related to compress, deleting file history including set-up file in your pc, install again this compress and ensure that there's no more any previous compress related file in your pc. after installation make sure that your antivirus is disable so that you can run the ----- or emulator to activate the compress..
    that's all
    duazo2009
