Thread: Required flow rate of regeneration gas during vacuum swing adsorption
  1. Required flow rate of regeneration gas during vacuum swing adsorption
    Hi folks,
    I am trying to understand a particular design for a vacuum swing adsorption system. This particular system is being used to dehydrate a gas stream using zeolite 3A with two packed beds (one regens while the other is in the pressurized adsorption cycle).
    What I do not understand is how they designer chose the flow rate of regen gas to supply to the regenerating column. The regen gas comes in the form of a slip stream split off of the dehydrated product flow. They are recycling approximately 50% of the dehydrated product back for regeneration which seems astonishingly high.
    Any assistance is duly appreciated!
    Re: Required flow rate of regeneration gas during vacuum swing adsorption
    There is a method in GPSA to calculate the regeneration flow rate.
    please i need any book or document about design an unit of pressure swing adsorption
  1. Pressure Swing Adsorption - howto design and optimize
    By technicaldreamer in forum Petrochemical
    Last Post: 02-27-2015, 10:52 PM
  2. Replies: 0
    Last Post: 02-20-2014, 12:48 PM
  3. cyclic pressure swing adsorption code
    By sharkyoungman in forum Oil And Gas Process
    Last Post: 09-26-2011, 01:37 PM
  4. cyclic pressure swing adsorption code
    By sharkyoungman in forum Engineering Programming
    Last Post: 09-14-2011, 12:46 PM
  5. Replies: 1
    Last Post: 07-15-2010, 05:47 PM
