Thread: PDS ISO Batch Extract Utility Share
  1. PDS ISO Batch Extract Utility Share
    This utility can save some hours for designers. It don't need "bulk load lines" and "create batch job input" within PDS, all you need to do is to list models/lines in excel sheet, and then select the lines to submit ISO. You can choose the lines conveniently by utilize excel filter/sort function. And it can split the lines into more batch ISO queue automatically if the ISO server monitor utility is applied. It can submit ISO from computer without PDS installed even.
    Attached Files Attached Files
  3. Re: PDS ISO Batch Extract Utility Share
    great work buddy..... Thanks
  5. Re: PDS ISO Batch Extract Utility Share
    can you elaborate more. like how it works
    Thank you.
  1. Extract Highlighted Text from a PDF File
    By Mohamed in forum Computer & Internet
    Last Post: 10-28-2013, 08:40 AM
  2. Extract fault lineaments
    By AlvieAR in forum Geology & Exploration
    Last Post: 04-18-2013, 06:16 AM
  3. Looking for ASME Academic Extract
    By bryandown in forum Mechanical Engineering
    Last Post: 08-05-2012, 06:17 PM
