Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 27
Thread: Casing Design
  1. Casing Design
    Can someone help me about my research. I would like to learn the concepts needed for casing design, but i don't know where to start.
    I hope for everyone's kind assistance. Thanks!
  3. Re: Casing Design
    Hi Vanket,
    the best way to start is to have a basic understanding the purpose of each casing string installed in a well. once you familiar with the name, common size, grade , then you'll go the geometry of the well itself with respect to the available size. After understanding this, you may go to the engineering calculation. all these are available in the internet..for theory and practical, i would suggest to you Hussein Rabia well engineering material.
    Re: Casing Design
    Re: Casing Design
  7. Re: Casing Design
    Thanks for the help guys! I've read the two books and it was very helpful. But i'm having a problem for deviated and horizontal wells, I don't know how to solve for collapse and burst??
    Re: Casing Design
    use TVD depth to calculate collaps and burst
  10. Re: Casing Design
    Ohw.. i see! Thanks! can you give me an example solution for horizontal well? I still can't imagine the process for horizontal well. I really appreciate your help. Thank you very much!
    Re: Casing Design
    open this book ''Rahman - Casing Design, Theory and Practice'' and go to ''Chapter 4'' there is an exemple
  12. Re: Casing Design
    Thanks! By the way, i'm having a problem about reference point. In rabia, what is pressure in surface? is it RKB or at the wellhead? Where is the reference point? How about in subsea and offshore rigs?
    Re: Casing Design
    i worked only in onshore (land rig), the reference point is wellhead (landed point of casing in casing hanger)
  14. Re: Casing Design
    Ohw! Thank you sir! your a great help. I was very confused between ground level, RKB, mean sea level, wellhead.. hehe. Because i've read the example from rabia, the part where the burst from pressure testing was calculated. Why was the back up gradient 0.465x2200? Should it be 0.465x(2200-60)?
    the MSL=60'
    GL or seabed=140'
    the casing shoe depth=2200'
    reference point:RKB
  16. #12
    Re: Casing Design
    there is an error the true value of back up is 0.465x(2200-60)
  1. Casing Design Spreadsheet?
    By rdwiens in forum Drilling And Workover
    Last Post: 07-29-2014, 10:23 PM
  2. Casing design software
    By diantupang in forum Drilling And Workover
    Last Post: 05-23-2013, 07:55 PM
  3. Casing Design Software
    By chelik in forum Drilling And Workover
    Last Post: 11-05-2011, 04:30 PM
  4. Casing design
    By Damir in forum Drilling And Workover
    Last Post: 05-22-2010, 04:28 AM
  5. Casing Design in NorthSea
    By Howpok in forum Drilling And Workover
    Last Post: 03-16-2010, 02:50 PM
